  • Guests: 18
05/04 Matthew T. (35)
05/04 Amrit Deshmukh (60)
05/05 Alexandre (32)
Universal DRSSTC Driver V2.5 (Sold Out)
Goodchild
Wed Apr 10 2013, 04:02AM
This board can be used for a QCW if you are using the traditional buck modulator and bridge design. I tested the board up to 500Khz no issue with logic and/or gate drive. For phase shift modulated designs that is another story....
I plan to release it soon. I have parts coming in this week (7mm inductors). I will have it tested in a DR by next week. At that point I will upload the files to the website.
Keep in mind that this is a very new board design, so if you use it think of it as beta testing at this point.
I will post a link to this thread when I do upload the files.
Dr Hankenstein
Thu Apr 11 2013, 03:26AM
Dr Hankenstein Registered Member #1642 Joined: Sun Aug 17 2008, 11:36PM
Good job, Eric!
Nice job on the layout and special thanks for taking the time to fix the original errors. I am impressed! I like the option of using both popular types of fibers. I am looking forward to using your board in the Zotzilla rotating spark gap-to-DR conversion. Ya, baby!
-- MODERATOR EDIT --
Original text removed. None of that talk is welcome here. (Behavior and Conduct part A)
Kind Regards,
Hank
Dr. Drone
Thu Apr 11 2013, 03:46AM
shades
Goodchild
Thu Apr 11 2013, 08:40AM
Thanks for the compliments, Steve Wards's design was awesome to begin with, I just tweaked it so that more people could use it.
Standardization!
I can't wait to see this new hybrid convertion you are building Hank. It will for sure be one of a kind!
Thu Apr 11 2013, 11:33AM
Good looking PCB, but I still prefer my own single sided through hole version, we can call it the version UD0.1 :D
The error in the TL3116 network, was that in the original schematic or just on the original PCB?
Dr. Drone
Thu Apr 11 2013, 03:35PM
shades
teravolt
Thu Apr 11 2013, 07:30PM
does your new board use surface mount or conventional IC's and have you made any schematic changes? it would be cool if there was a board for a QCW as a addendum to UD2.5 or a standalone with conventional or surface mount board.
Matt Edwards
Thu Apr 11 2013, 09:40PM
looks good man!
Goodchild
Fri Apr 12 2013, 01:03AM
teravolt wrote ...
The board pictured above is the actual board. So yes it does use SMD ICs. Yes there are also several schematic changes. I will publish the schematic and board files later tonight hopefully.
I may publish a QCW board I'm working on. But that is ways down the road. It is a design that uses ZVS and phase shift modulation. That will be a ways off as I still need to find the time to finish it.
teravolt
Fri Apr 12 2013, 01:44AM
nice job I have been viewing the thread from work and the pictures were blocked.
