  • Guests: 25
05/07 a.gutzeit (63)
05/08 wpk5008 (34)
05/09 Alfons (36)
non-DR QCW's
Sat Apr 07 2012, 05:14AM
The DR part is mainly just a convenient way to get a higher system Q without having to store all the energy in the secondary... that is to say, you could make a single resonant coil, but its gotta be much lower impedance to work as well as a DRSSTC would.
I think a regular SSTC (single resonant) would work OK if designed right. The secondary impedance needs to be a lot lower than what most people use, that means lots of toroid capacitance and very little secondary inductance. Id probably try getting the reactance at resonance to be less than 20K ohms as a start (it might benefit from being even a lot lower depending on the drivers output impedance). Keeping the Fres above 320khz or so seems to allow for the branchless spark growth, which seems to primarily be due to lower voltage spark growth. Going higher than maybe 360khz seemed to have no benefit in my experiments, though may be useful because it lowers the required output voltage per spark length. My straight sparks needed about 65kV peak when grown to 4 feet, at 365khz.
Steve Ward's original QCW used DC bus voltage modulation without any current feedback, so that is the approved way of doing it. My experiments with current feedback were none too impressive, and I plan to stop using it.
I think i got lucky that the bus modulation worked so well at controlling the spark power. If the DRSSTC was a stiffer voltage source, it wouldnt work well at all, and then i think current regulator would be better. Anyway, dont stop using your control technique until you try the higher frequency coil first! Or at least mess with the ramp parameters to be sure it doesnt work.
hvman
Sat Apr 07 2012, 02:06PM
hvman Registered Member #598 Joined: Thu Mar 22 2007, 07:41AM
I tested my half bridge SSTC with a 580 kHz seconadary and I achieved up to 1 foot sword-like sparks. I don't use modulator, coil run with a synced interrupter at half wave rectified mains.
Sat Apr 07 2012, 02:55PM
hvman wrote ...
I have been and am working on a DRSSTC version of the same, a synched interupter to conduct for the first 5ms of the 50Hz period, but its trapped in a box while im moving :)
