  • Guests: 24
05/27 Daniel Davis (53)
05/29 Zonalklism (33)
05/29 Dr Hankenstein (67)
30 LED blacklight
Wed Jul 26 2006, 11:55PM
I'd try a simple boost converter. (control IC, inductor, and MOSFET, and a few caps) You can monitor current through one string and use it as feedback for current regulation. Any boost design should work fine for this.
Fri Jul 28 2006, 11:02PM
I used to paralell LED's without resistors many times actually and had no visible differences in output power or greater current missharing.
Those were lower power normal led's altough, but I don't think you are really going to have trouble with paralelling a bunch om similar led's.
Different led's paralleled together without resistors usually cause problems. I once put a led damaged by heating paralel to about ten others (wich seemed alright) and it was noticeably dimmer.
Fri Jul 28 2006, 11:44PM
For white led's I've used a (very) simple boost convertor
which worked well.
I made a 'blacklight' illuminator for my handycam and used 'constant current'
which works very well and is very simple and quite efficient
more importantly it gives constant light/uv output.
D1 to D6 are uv leds
Q1 any pnp
Q2 any npn
R1=R2=(Vled-Vbe)/Iled
OOPS ! D1 to D3 on the right should be D4 to D6
This circuit will give constant led current for 11volt supply and above
Sun Jul 30 2006, 06:33PM
I like that circuit Sulaiman! It's pretty sneaky shades
Sun Jul 30 2006, 09:28PM
hm, ''many diodes make constant-current source work''.
If i'm asked, I would simply put all LED's in paralell and power them from 3x 1,2V nicd (3,6V).
I wouldn't care a lot if I have 3mcd brightness difference between two of them (for the sake of simplicity and compactness of the system).
