  • Guests: 21
lokeycmos (42)
05/24 Simon Barsinister (62)
05/27 Daniel Davis (53)
05/29 Zonalklism (33)
69mm Electric Ducted Fan, 2.8 lbs Static Thrust...
2Spoons
Mon Feb 06 2012, 09:54PM
Can you get them designed for reverse rotation? otherwise you need some way to compensate for the fan torque.
Tue Feb 07 2012, 01:06AM
2Spoons wrote ...
Im not using the turbine any more the turbo lag is to great. The better power 10 motoe will use a conventional prop, and one will be CW the other CCW.
Carbon_Rod
Tue Feb 07 2012, 02:38AM
The aeroquad software and hardware wiki:
Note a Directional Cosine Matrix is faster on some chips:
git hub (based on sparkfun IMU):
Some of these designs are fairly amusing:
Cheers,
Tue Feb 07 2012, 02:50AM
Carbon_Rod wrote ...
Cheers,
Great links!!!
the guy in the last link hurt himself sad
Carbon_Rod
Tue Feb 07 2012, 02:57AM
He also flys a mini quad into a tesla coil:
These kind of students can get a few people injured.
Tue Feb 07 2012, 04:53AM
Its interesting to see the HV strike only temporarilly reset there drone.
Daniel Kramnik
Sat Feb 11 2012, 02:38AM
Daniel Kramnik Registered Member #3885 Joined: Sun May 15 2011, 12:47AM
Hey guys, I built the Tesla coil he flew that into!
=P
Sat Feb 11 2012, 02:50AM
im switching over to two 9 x 4.7 counter rotating prop pairs.
