  • Guests: 17
BlakFyre (36)
SENTRY (31)
04/30 BlakFyre (36)
04/30 SENTRY (31)
05/01 Shaun (34)
Electronic variac for (DR)SSTCs
Maurizio Valvo
Fri Aug 15 2014, 12:15PM
Maurizio Valvo Registered Member #3219 Joined: Mon Sept 20 2010, 09:06PM
Thanks Steve.
Your Mk2 is the one based on UC3526 and TL494?
I am mainly concerned about the choke, it needs space ... but maybe mains inductance would be enough in my case!
Fri Aug 15 2014, 01:21PM
The problem with using mains inductance is that the voltage dropped across it also affects the trigger signal. This can cause instability when the load is a large capacitor bank, as I explained earlier.
Besides stabilising the circuit and making triggering less critical, the inductor also improves the power factor considerably.
Maurizio Valvo
Sat Aug 16 2014, 10:54AM
Sure, I understand. A clean trigger was indeed somewhat critical to obtain already in my design and needed me to revise the circuitry a couple of times.
I will balance your design, which is for sure the easiest and safest way, with respect to developing a PWM converter.
Thanks again for your tips!
