Registered Member #95
This is amazing! I've been following this thread since it started, and have to say I'm impressed by what you guys and gals have discovered. I'm tinkering away at my own setup right now, and hope to try some American 2X2A tubes I have.
Your pinhole images are fascinating Leslie, you're using an intensifier tube to see this if I'm not mistaken? I'm interested in the details of the pinhole itself too. Reading about pinhole cameras it would seem we need a micrometer sized hole to get focused images, if using a practical focal length.
Oh, and to help aid visualization of the x-ray source, here's Radu's enhanced images beside Stella's heat-shield pics. The detail is incredible!
Registered Member #1134
radhoo wrote ...
Can you post a photo showing your setup for this experiment? What have you used to record those pictures with such an excellent quality?
ps2: Les' images with some additional software enhacement. I would really like to know more on how these photos where made. Great job, so many details visible!
I will take some photos at the beginning of the week, as I am away till Monday night.
The apparatus consists of one of my very sensitive x-ray Fluoroscopes described here, (except this version uses a Generation II tube),and a lead pinhole camera assembly.
An 8 inch long truncated cone was fabricated from lead sheet. The tip of the cone is flat, with a large hole drilled in it to permit mounting a pinhole of any size. . The pinhole is about 0.05mm across, and was made in a separate thin piece of lead.
This is simply mounted on the front of the fluoroscope, and pointed at the x-ray source. The output screen in viewable in real time to dark adapted eyes, but the digital camera requires a 15s exposure to produce a bright enough image from the screen.
The cone of the pinhole camera is made so long as to permit some decent magnification of the x-ray sources.
Next week I will take some real close ups of the anode, and try and setup the webcam to take some very long exposures, to see if the weaker emissions the tube can be imaged in this way.
Registered Member #1938
Hi Eirik!
Thanks for joining in!
I'm a bit confused: Are you saying Les is using an intensifier tube? I assume he is also using a fluorescent screen of some kind to filter the regular light (there is plenty while the tube is powered on) from the x-rays. Les, we'd like to see your setup. LE: cross-posting: ok, looking forward to see your pictures. thanks for the details!
The American 2X2 might not be very good at this, I've used 2 different tubes with not much output (there are some pics a few posts above).
Stella, thanks for the graph a few comments: - it shows a point-like target - bremsstrahlung radiation goes in the electron direction, so if the target is the shield, this is not the cause for the abundant x-rays - which leaves: the K X-rays (now I wonder what the shield is made of: you've mentioned it was magnetic some time ago). So for the point-like target , the graph shows a sphere like distribution all around the target (I see a small circle).
One thing that doesn't seem right with the current shield target idea: The target is white-hot! The shield doesn't even get red...
Registered Member #543
radhoo wrote ...
This is how an electron bombardment target looks like at 50KV pd: White-hot!
I think perhaps I should have added a few words of explanation to the graph.
You will notice that at 50keV, there is significant radiation at 90° to the electron beam, but at 500keV the bremmstrahlung follows the direction of the electron beam much more closely. i.e. the tendency of the bremmstrahlung to follow the electron beam direction is energy dependent.
Now, if you have 40kV on your anode, about 1% of the X-rays produced will have an energy of 40keV, and all the rest will have less, down the lowest energy that can transmitted by the glass envelope (say 15keV) tending to become more and more isotropic with decreasing energy.
And to these increasingly isotropic bremmstrahlung can be added the isotropic characteristic rays of the elements in the target.
Your observations about heat dissipated in the anode seem to confuse X-ray energy with tube current and with fluence. You could have 100kV across a micro field emission tube which drew but 1μA, for a total power of 100mW. It would emit a tiny amount of 100keV rays, but their fluence - quantity of photons per square metre - would be very low indeed, and the tube would not get significantly warm.
Conversely, you can find Be window XRD tubes with just 10kV on the anode that gobble up 1kW or more and need high pressure water cooling.
On a separate note: FILTRATION
Filtration with Al, Cu, or Ag foils may improve the resolution of the pin-hole images.
Uzzors wrote ...
Thanks and yes, its a GenII image intensifier tube with GADOX scintillator bonded to the face plate, like my fluoroscopes. The pinhole is 0.05mm diameter. Micron sized would be better, but even with a system gain of around 40,000 very long exposures would be needed. (a project for next week).
Oh and thanks for the comparison pics post, it certainly clarifies what is being observed here.
radhoo wrote ...
White-hot!
It certainly looks white hot, however that coating is brilliantly fluorescent under the impact of electrons! Note the comparatively dark uncoated region at the end of the heater.
If you really push the tube the shield can be raised to yellow heat under the impact of electrons.
Proud Mary wrote ...
The fluoroscope is already filtered with 0.5mm Aluminium. A smaller hole and longer exposure is what is needed now.
Your observations about heat dissipated in the anode seem to confuse X-ray energy with tube current and with fluence. You could have 100kV across a micro field emission tube which drew but 1μA, for a total power of 100mW. It would emit a tiny amount of 100keV rays, but their fluence - quantity of photons per square metre - would be very low indeed, and the tube would not get significantly warm. Conversely, you can find Be window XRD tubes with just 10kV on the anode that gobble up 1kW or more and need high pressure water cooling.
What you're saying here is P=UxI and that more electron intensity will produce more x-ray intensity "fluence?", while the potential difference is responsible for the energy and penetration power of the x-ray photons. The x-ray intensity is what follows the inverse square law (since it's radiant energy) and we're all using it to keep us safe while experimenting. etc. Perhaps I wasn't clear, my idea was a bit different: we have different dissipation on the filament as compared to the relatively bigger shield, but still it would have been nice to actually see the shield being struck by electrons and emanating heat.
plazmatron wrote ...
It certainly looks white hot, however that coating is brilliantly fluorescent under the impact of electrons! Note the comparatively dark uncoated region at the end of the heater. If you really push the tube the shield can be raised to yellow heat under the impact of electrons.
Yes, it looks white hot, and when you unplug the supply you will see it get orange, then red, brown and black. About the shield, I would like to see it getting yellow, but I guess the filament would melt first. Still for such an emission intensity, I would have expected the target to become more visible while under electron fire.
