  • Guests: 17
a.gutzeit (63)
05/08 wpk5008 (34)
05/09 Alfons (36)
05/09 Coronafix (51)
High Voltage Planar Ferrite transformers. ( Intial Experiments )
Sat Nov 01 2014, 10:11AM
The same way you would get inner and outer connections to your single coil !
You will have several individual transformers, each with it's own windings,
not one continuous piece of wire for all transformers.
The connections between secondaries requires a connection external to the transformers.
that's why you can replace a single unit.
... alcohol and logical thought processes are mutually exclusive ! cheesey
... alcohol and high voltage experimentation more so cry
Sun Nov 02 2014, 04:36AM
ok ive got some blue PLA for my 3d printer. PLA supposedly has a dielectric strength of 6.4MV / cm, which equals 13kV per 0.001 for us normal people smile. so 13kv / 5 = 2.6kv per mil, thats a generous de-rating i think.
i dont know how frequency effects PLA.
ill make and wind one bobbin, epoxy filled, well see if that works.
