Registered Member #3340
Hello, i just became a member of this forum. Is the schematic of the tesla coil depicted first on this thread available? If so, i would like to take a look because i couldn't make a whole circuit schematic from the attached pdf. Thank you very much!
P.S any tips/advices are welcome because i am new in the field of electronics : )
Registered Member #3624
That's so cool! I downloaded the pdf for flash camera spark gap tesla coil and I tried building it. It only gave me a 2mm discharge, but I ran it on a single AA battery. It seems like all the HV people I see on the internet are on this forum.
Zack wrote ...
Try running it from 2 batteries. Also add more turns, like 6 for primary(3cm radius) and 600 for secondary(2cm radius). Mine puts out about 3cm arcs and can dimmly light a cfl.
Registered Member #3898
i built the cockroft walton multiplier the way you said. i think i am getting 300V AC out of my flash board like you said. when i connect it to the CW and i mesure between out put and ground with one stage i get 600V pulsating DC which is what i expected. then i and a second stage and mesure between output and ground i still get 600V. and the same with 3 stages. iv tried with 6000V 470 pf( products_id=1620692), 3000V 330pf( products_id=1619903) 2000V 470 pf( products_id=1619883) and 500V caps. with 1000V diode.
Registered Member #4047
Hello, does anyone know if you can just use a simple wall adaptor instead of batteries so it can run as long as you want without having to replace the batteries every few minutes?
Registered Member #1225
teslaozone wrote ...
Registered Member #952
Yep, I suppose it'll work fine. Don't go much above 3V to avoid breaking the tiny transformer or the drive circuit.
I haven't been even lurking around here for about a year or so. :o
what is the max amps i should have in a wall adaptor? I tried a 5v 2a adaptor. And, i got a nice little explosion...
Also, i tried running a 9 volt battery on only one flash board and i got about 1" arc, although the transistor on the flashboard quickly over heated and died. Is there any way of over running this circuit but heat sinking the transistor? It seemed to be the only problem when running with a 9volt/ thanks alot for this cool project. Im building it for my girlfriend... am i cool or what :P
Actually I think input voltage is the most important limiting factor. Once I tried running a flash board transformer at 9v. The transistor died, but an eyeblink before there were sparks in the transformer. I don't believe the transformer would work at more than ~3V primary voltage, because otherwise the secondary voltage will be too high and insulation will fail.
