  • Guests: 32
07/16 Gavin (49)
07/16 Froskoy (33)
07/16 UnHappy1 (59)
V3 Coil Carbine
ben5017
Thu Apr 25 2013, 12:11AM
ben5017 Registered Member #3315 Joined: Thu Oct 14 2010, 04:23PM
Max:
no worries.
here are some pictures to keep your interest and motivation in my project. The frame will be cut out on my router I just got operational. I will draw it up on the computer once I know the dimensions of the sub systems and parts. Just waiting on a few more things.
As for my code. I need.
4 stage firing code
- Sensor calibration for each stage (done but needs integrating)
- Limits on max igbt on time for each stage,
- Consecutive coil firing safety
- Debounce each stage
Injector Firing code
- One-shot trigger circuit
- Switch selectable monostable or astable mode
- Debounce
- Adjustable pulse length
Drum Mag
- Fatuba servo code
- Integrate IR reflective sensor servo / encoder haven't decided yet (suggestions?)
- Adjustable sensor sensitivity
- Manual "jog" of a specific degree rotation when button pressed
I hope I didn't just scare you off. I just want to get the main firing code working and add the bells and whistles after
13 102
08 666
40 998
32 568
11 531
Maxwell
Thu Apr 25 2013, 01:46AM
Maxwell Registered Member #8497 Joined: Tue Dec 04 2012, 06:24PM
Alright.
Can you provide a datasheet or link to the optical sensors you're using? I'm assuming if you're requesting a calibration that you have analog sensors. Are you hard-set on these? I am using two of these:
for benchtop chronograph timing and they work flawlessly...The arduino is simply looking for a 1 or 0 from the sensor (high/low)...I don't have any calibrations. Either the beam is broken or it is not. Granted, you need something a little narrower for fitting over the barrel.
---> I've never had success with an IGBT and the arduino - from my understanding they're somewhat latching. If you know the controls behind triggering an IGBT on/off I can write a brief timer to control it.
---> This can be done by through circuitry - always grounded except when given signal.
Debounce each stage
---> Probably won't be necessary as everything is going to be digital.
--->This is where we would use the digital de-bounce and code staging to record code status.
--->I don't understand
--->Simple.
Drum Mag
I've never done servos. There are tons of Arduino libraries for servos...I've used stepper motors before which are easy. Are you looking for feedback to determine if a chamber is loaded or not with the IR reflection? Manual Jog shouldn't be an issue.
I don't see any problems with these requests.
ben5017
Thu Apr 25 2013, 02:07AM
max:
I made the sensors out of a IR emitting diode and a IR phototransistor I got of mouser. I will supply the data sheet. They were working great when firing off of my old 2 stage 555 circuit. I am not set on anything but I think mine will do the job. (you have any experience using photodiodes? read they were much quicker)
I am having the arduino controlling a igbt driver, not directly to the gate of the igbt. I will send you a link the that data sheet as well
Semi auto or full auto
that was the plan. open to Ideas. maybe the encoder is the way to go
Maxwell
Wed May 01 2013, 05:57PM
Hi Ben5017,
While I'm working on this,
If you want to familiarize yourself with basic C++ code, the arduino notebook published at:
provides a lot of good background!
ben5017
Wed May 01 2013, 07:09PM
I will most defiantly check that out. BTW if you ever need any parts made, I would be more than happy too cut them out for you on my router, as a show of appreciation.. Just PM me.
Maxwell
Thu May 09 2013, 12:44PM
Hi Ben,
I would anticipate having a functional code tomorrow afternoon.
For clarification again, which model arduino will you be working with?
ben5017
Thu May 09 2013, 04:34PM
good stuff max, i plan on cutting the frame out this weekend too.
Im using a arduino mega 2560 for now. will probly switch it up to a smaller model as space is in short supply.
Maxwell
Wed May 15 2013, 02:28PM
Update: code does not function on my mega. (it does on my newer leonardo). But @Ben, no I haven't forgotten about you. Just de-bugging. I have a feeling that the interrupts I'm trying to call are not translating as I expected between boards.
The mega has more interrupt channels than does the other models.
However,
the code for the trigger, armature detection, firing works fine.
ben5017
Wed May 15 2013, 09:39PM
MAX: Sounds good. Here is a little more motivation. still got away to go .....
construction will be 5mm abs.
What is the most compact arduino you think I could get away with? I want to leave a little room for possible upgrades in the future.
1368653960 3315 FT147269 Iso
ben5017
Wed May 15 2013, 11:50PM
update
1368661825 3315 FT147269 Iso2
