  • Guests: 22
AlexRU73 (39)
05/19 cbfull (52)
05/19 Steve Ward (39)
05/20 Vaxian (17)
smaller coils (and a 12MHz target)
WaveRider
Wed Nov 15 2006, 08:53AM
BP.. It's outstanding work!
Perhaps if you made all the wiring as compact as possible (short leads, no "big" loops where your primary connects to PCB, etc.) and shielded everything, your bench instruments should not go crazy (I noticed this too before I put my coil in a faraday cage.) You are no doubt radiating significant harmonic power as well as possibly inductively coupling into power-supply leads... Just a thought....
EMC...it's not just for breakfast anymore! cheesey
Cheers,
Bill
Avalanche
Wed Nov 15 2006, 09:01AM
Amazing work, love it!
That breakout is scary, looks like there's a lot of rf current going into the streamer suprised
ragnar
Wed Nov 15 2006, 09:32AM
Thanks Peter, Avalanche, WaveRider =)
In these pics here, you can see the output board from close up:
1163560079 63 FT17052 1356module 1163488062 63 FT17052 Sddfet
My primary is connected straight to the drain, i.e.:
+VE >> PRIMARY >> MOSFET >> GND
On that circuit board, the DRAIN and +VE are the big pads on the left and right of the FET, respectively. I've snuggled the decoupling cap in there as best as I can, and you can see where the big negative pad connects straight to SOURCE.
I could connect the primary straight to the heatsink underneath the positive pad (not using insulators, for now, which greatly helps with removing heat from the TO-220 package).
It's interesting to note I'm getting ~100V peaks on the drain with a 32V supply. The IRF730 is a 400V FET, so if I can keep it well enough in tune, I'd consider tripling the supply voltage =D You guys can flame me later.
I should also play around with the turns and coupling on the primary -- I'm sure that two turns isn't optimal.
Keep the ideas coming, thanks again guys =)
Wed Nov 15 2006, 11:00AM
Wow, excellent work BP! suprised shades
ragnar
Sat Nov 18 2006, 12:10PM
[Forgive the double post -- I hit 'submit' twice -- my apologies. angry]
ragnar
Sat Nov 18 2006, 12:11PM
I raised the secondary by putting two tiny C-shaped aluminium heatsinks over the primary to sit it on, and now he resonates at 12.7MHz. I also get a higher voltage (or at least, longer breakout) at the top of the coil. The plasma appearance is just breathtaking at such high frequencies -- it looks less and less like an electrical discharge and more and more like a tiny blowtorch flame.
The wire forming my secondary (0.5mm, or 0.02in)gets ridiculously hot after a few minutes of operation... considering the skin depth (or lack of!) in copper at 12+MHz, I shouldn't be surprised.. If I had thicker wire, I'd like to rewind it with more turns and a smaller diameter.
I will also adjust primary turns and consider enclosing in a cage.
1163851881 63 FT14290 1356dlight1
1163851881 63 FT14290 1356dlight2
1163851881 63 FT14290 1356dlight3
1163851881 63 FT14290 1356dlight4
Avalanche
Sat Nov 18 2006, 01:24PM
Nice pictures! How does the discharge compare to your 'lower' frequency class-e coils (in terms of appearance/impressiveness more than size)? I'm seriously considering cutting my frequency in half with my current setup, as it should be easy to get 6Mhz at quite a bit of power with this lot.
Sat Nov 18 2006, 01:48PM
How long is that spark BP?
When I lower my power (1,5Mhz) to few watts I can get a 1cm spark looking like that;
My problem is that I usually don't use enough filter caps so spark buzzes, but if power is very low it just hisses faintly.
ragnar
Sat Nov 18 2006, 01:55PM
The angle of the photo doesn't help, but that spark is ~9-10mm in length.
When the signal generator is stable, the arc makes NO noise. In still air it does NOT even appear to move.
If you didn't already see them, the pics from my 6.5MHz coil can be found here:
http://www.infringingwebsite.com/matt/6.5mhz/
Notice how in all the pics, although the edges of the discharge are a very fuzzy plasma glow, it *still* branches out into 'streamers' of some description.
The 6.5MHz discharge still retains a lightning-like appearance that causes hissing/rippling noises, which is why I set my aspirations at 13.56MHz.
As I coax more and more power from the coil (I need to get my Variac operational for this), things will get more interesting, and I think the rippling noises will start again.
Sat Nov 18 2006, 02:58PM
Yeah, exactly same thing for me at 1,5Mhz neutral
It looks like a small sword and doesn't move around.
Except I could never take so good pics of it ill
