  • Guests: 12
cbfull (52)
Steve Ward (39)
05/20 Vaxian (17)
05/21 Dalus (34)
05/21 Kizmo (37)
Would this be a viable controller?
StormInABottle
Wed Jul 30 2014, 11:36AM Print
Hello, I have been thinking of replacing the typical SSTC/DRSSTC controller with an arduino board, Like the UNO or the Mega 2560, Would one of those programmed to give a pulsed signal that's the exact resonant frequency of a specific coil work as a viable controller? I am pretty sure you would need some Mosfets to amplify the output if you want to switch IGBTs, I am also sure you can set duty cycle and also play music
Is that viable?
Sigurthr
Thu Jul 31 2014, 12:46AM
Due to the way the uC functions and its lack of a RTC it cannot provide a stable enough stream of pulses for direct driving a TC. Likewise, you can't even precisely time any pulses shorter than 1mS or so. You start seeing delays not accounted for in code from the instruction execution time that muck everything up. There are a few libraries out there that user timer.1 built in timer chip but you're restricted to fractions of the 16MHz oscillator up to 1MHz in roughly 100KHz steps.
StormInABottle
Thu Jul 31 2014, 01:53AM
Sigurthr wrote ...
For example, For 56Khz
Using timer 1, You can set the prescale to 1 and just set the compare match to 142
Are you saying that using Timer 1 will give more reliable results ?
Sigurthr
Thu Jul 31 2014, 02:48AM
It's more reliable but it isn't nearly reliable enough for TC operation. You're going to get hard switching and missed/extended pulses in the pulse train. I tried it once with a simple SSTC at around 300KHz and the bridge output looked horrid because a SSTC bridge does not tolerate running on the capacitive side well at all (below resonance). I wouldn't try it on a DR coil ever. Maybe at 56KHz there won't be as many errors in the pulse train, but my experiments didn't show it to be promising enough to try.
Also, you can't account for the dynamic load that the streamers present on the secondary and their detuning effect. This isn't a huge issue, I've run SSTCs off of a VCO before, and in some applications it is actually better than real feedback as output power fizzles out to nothing in case an on-looker comes too close and tries to touch the output. In terms of performance though it can't compare to feedback.
StormInABottle
Thu Jul 31 2014, 05:25AM
Hmmm, It should be noted that the arudino i have is the Mega 2560, So i have a couple more 16 Bit timers, Timer 3, 4 and 5 in addition to Timer 0, 1 and 2
I think there should be a way to make the signal more reliable.
Maybe have 2 timers running at the same frequency and then they are " Checked " against each other providing a cleaner, More reliable signal?
If 1 timer makes 5 mistakes in 5 places, The other makes 5 different mistakes in 5 different places, Checking them against each other should result in a more reliable signal.
Sigurthr
Thu Jul 31 2014, 06:21AM
Sounds like it is worth a try. I only have an UNO so it was already beyond it's capabilities (I'm sure I didn't write the most economical code).
StormInABottle
Thu Jul 31 2014, 06:55AM
Sigurthr wrote ...
Maybe also, Just maybe, We can make it auto tuning by setting the compare match to a variable, Said variable changes according to feedback from an antenna/bottom of resonator
Maybe..
Thu Jul 31 2014, 07:12AM
I've seen a uC based driver that works in just this way, and it was successful, however it is a serious real-time programming challenge. A DRSSTC burst lasts about 200 microseconds and within that time frame you have maybe 20 switching instants that you have to get right to within maybe 1-2us. And, you are aiming for a moving target, the resonant frequency of the coil changes during the burst as the streamer develops.
The driver I saw used a Cypress programmable system-on-chip (PSoC) and many of the timing functions were accelerated by custom hardware.
StormInABottle
Thu Jul 31 2014, 07:49AM
Steve Conner wrote ...
I would mainly be aiming for a continuous operation on a regular SSTC, A fiery thick arc is more interesting than interrupted DRSSTCs to me
Thu Jul 31 2014, 01:40PM
In that case, the control problem is much easier. No need to worry about missing the zero current switching points as an untuned primary SSTC doesn't have zero current switching to begin with. The Arduino would probably work out fine.
