  • Guests: 36
Alexandre (32)
05/07 a.gutzeit (63)
05/08 wpk5008 (34)
05/09 Alfons (36)
4hv.org :: Forums :: Suggestion Box
Add attatchments using the 'Edit' Function?
Muttyfutty!
Sun Sept 12 2010, 05:52AM Print
Muttyfutty! Registered Member #2915 Joined: Fri Jun 11 2010, 10:41AM
Hi, Just my humble opinion...
I've noticed there is no way to add attachments using 'edit'.
Unfortunately I am sometimes forced to double post.
I have observed other people with the same problem; Is there any workaround?
Thanks in advance,
mike
Sat Sept 18 2010, 12:36PM
Make a Post in the attachments board
then copy the URL on to your post =D
Muttyfutty!
Sun Sept 19 2010, 12:19AM
You are a genius.
Thanks you! :)
dmg
Tue Oct 05 2010, 01:06PM
I kinda agree though, will be nice to do a direct upload when you edit, and not just the first time you write your post.
