  • Guests: 26
05/07 a.gutzeit (63)
05/08 wpk5008 (34)
05/09 Alfons (36)
Levitating a coil
1 2 3 4
Tesladownunder
Sun May 14 2006, 10:53AM Print
Was reorganising my web site and looking at magnetic levitation stuff so thought I'd try a few things.
Here is an air cored coil out of a defibrillator output circuit. Don't know number of turns but the inductance is 10mH (I think). It is drawing 6.5 A at 100V AC to get the lift of about 1/2 inch off a 1/4 inch copper plate. It is tethered like a conventional lifter.
I did try levitating a MOT with the E section opened and facing down but really needed a better winding. Hence I tried a non cored coil.
Peter
1147603988 10 FT0 Maglevcoil1
1147603988 10 FT0 Maglevcoilcurrent
Sun May 14 2006, 11:20AM
Nice. Have you tried lifting anything with it?
Marko
Sun May 14 2006, 11:22AM
Always cool ideas from you! smile
I wonder if it could be stabilised using more than one coil, or fed with higher frequency current for more power.
Good work!
Tesladownunder
Sun May 14 2006, 06:37PM
uzzors wrote ...
Here is the 284g coil lifting a 217g solder reel (total 500g). Current was a bit higher and distance off the base was 1/4 inch compared with 1/2 inch before. There is a world of difference with an electrostatic lifter where the lift is (mostly) independent of the proximity of the ground and is far smaller.
Peter
1147631864 10 FT9533 Maglevcoilsolder
stop4stuff
Sun May 14 2006, 07:33PM
stop4stuff Registered Member #64 Joined: Thu Feb 09 2006, 06:25AM
very nice Peter,
I think i got a bit of an understanding why this works... something to do with eddy currents in the base copper plate? what i'm trying to get my head around is the AC, DC thru a coil would make the coil an electromagnet and it would repell off a magnet giving lfit, but AC? Does the base plate have a repelling magnetic force because of eddy currents induced by the coil? if so would a ring shaped base plate (same shape as the coil) give a better lift for less power?
intrigued,
paul
Sun May 14 2006, 08:07PM
Thats impressive! It can nearly lift its own weight! amazed
I thought the coil was levitating because the copper is diamagnetic?
Marko
Sun May 14 2006, 08:13PM
Just a simple eddy-current induction repelling.
stop4stuff
Sun May 14 2006, 08:23PM
could be diamagnetism, copper is slightly diamagnetic Link2
i've got a kilo of bismuth shot around somewhere (bismuth is 15x more diamagnetic than copper)... something to try tomorrow :)
Sun May 14 2006, 09:22PM
It actually wouldn't surprise me if it is diamagnetism, but with ac I am pretty sure it is eddy currents wink
I have a superconductor puck... perhaps I should try to rig up some coils to play with the next time my dad brings the LN2 XD
Alessandro
Sun May 14 2006, 09:26PM
Alessandro Registered Member #70 Joined: Thu Feb 09 2006, 08:19AM
It not diamagnetism as the most diamagnetic material on Earth (pyrolytic graphite) can only float mere millimeters above grade N50 neodymium super magnets and barely lifts its own weight.
It is eddy current repulsion from AC being feed to the coil.
Care to give more infomation on this TDU? frequency? power?
whoops, I read though the posts quickly and missed that part ^^
