  • Guests: 24
05/14 hvguy (41)
05/14 thehappyelectron (14)
05/14 Justin (2024)
NST supply in MO
Tesladownunder
Tue Feb 14 2006, 04:56PM Print
This is my power supply for a Tesla coil I am making for the physics dept at the Uni of WA.
I have a 12 kV, 110mA NST which I have crammed in to a microwave oven (MO) shell. It uses the original MO mains interference suppression, 5V supply, light, fan and lock out switch when the door is opened. I have added a solid state relay, large indicator lights, switch and there is a remote on switch with a flashing red LED on a 6 foot lead. There is a mains outlet which is switched which can run the fan for the coil and also have an optional variac inserted.
There is an inrush limiter and a few MOVs in different areas.
I have included a 3.5mm headphone type socket which requires a shorted 3.5mm plug to be inserted before the unit will activate. (in lieu of a keyswitch).
There is a Terry filter of sorts with 360 ohms 15W and a 440pf 40kV cap on each leg of the HV . There is alo similar circuitry inside the Faraday cage to the coil.
The fan has a fully shielded MO interference suppression circuit in a commercial "Lightning Protector unit" which I have modified.
HV leads are heavy 75 ohm cable with shield present.
So far it has survived a few minutes or so....
Peter
1139936174 10 FT0 Teslaphysicsnstsupply1
1139936174 10 FT0 Teslaphysicsnstsupply2
1139936174 10 FT0 Teslaphysicsnstsupplyrear
Tue Feb 14 2006, 05:16PM
Very cool. You never fail to impress me with all the stuff you do down there.
Part Scavenger
Tue Feb 14 2006, 06:10PM
Really, where do you get all that time? Don't you have a job?
ragnar
Tue Feb 14 2006, 07:56PM
Job AND wife AND kids AND spiders and snakes and steve erwin... :P
I love the "stuff in a MO" concept!
