  • Guests: 19
hvguy (41)
thehappyelectron (14)
Justin (2024)
05/15 Linas (34)
05/15 Toasty (29)
05/16 kg7bz (68)
Thermite VS HDD
cduma
Wed Apr 28 2010, 10:34PM Print
I made a 80:30 mix of FeO2 and Al and place it ontop of my HDD lit it and ran. Fire, smoke and molten metal follow and the HDD survived and was literally in a crater with untouched ground underneath it like in the cartoons. How can I melt my HDD?
Wed Apr 28 2010, 10:59PM
cduma wrote ...
Pack it in a few lbs of charcoal, in a cavity formed by stack of bricks, with an air blower or good natural convection. Bronze age technology still works.
Hon1nbo
Thu Apr 29 2010, 02:16AM
how much thermite did you use? - I never have a problem, and you could always stick it in a flow pot and bury it in the thermite if in doubt
-JImmy
MinorityCarrier
Thu Apr 29 2010, 06:33AM
5:3 casting plaster:Aluminum dust cast as a form about the size of a coke can, with a hole in the end, will produce a hi-temp jet from that hole that I guarantee will melt the HDD platter.
Nicko
Thu Apr 29 2010, 07:41AM
HDDs are amazingly tough. I used to destroy my company's old HDDs with a 12g with #6 shot:
1272397404 1334 FT57865 P1020670
However, whilst that one above destroyed a laptop drive nicely, I found the 3.5" platters are pretty much immune to lead shot, and whilst the platters were severely dented, they were rarely punctured, even from close range.... I haven;t tried steel shot yet...
As I worked for a financial institution which had serious data, i.e. valuable enough for people to use expensive recovery techniques if they got hold of any of our drives, I switched to using a proper destruct company - pretty cheap - worked out at about USD 10 /drive, and we got certificates of destruction for the auditors (need the paper trail!). The company I used was:
There is a nice video on the page of the process:
I like the nice flash of flame as the rare-earth magnets suffer...
Dr. Slack
Thu Apr 29 2010, 06:46PM
So why does a rare earth magnet flash when you crunch it?
quicksilver
Fri Apr 30 2010, 03:12PM
The rare-earth magnets in HDD's are great. It's a pity not to pull them out. I once got an old 5" SCSI drive that had several of the strongest magnets I have ever had, in it. I still have them and (no exaggeration) they individually can pull 225 lbs off the floor. (I tried it with Olympic weights & was shocked, it was so powerful.
Why in Heavens did you RUN when you lit the thermite? You can't see what's happening if you run.
quicksilver
Fri Apr 30 2010, 03:16PM
Dr. Slack wrote ...
I believe that was a simple spark of scraping steel: I played it back and it didn't come from the corners where a magnet would be in a IDE drive, plus the wheels were turning pretty fast.
Nicko
Fri Apr 30 2010, 06:01PM
Dr. Slack wrote ...
Good question - that is what I was told when I asked them what was happening. They (and other similar companies) have stands at Infosec, the UK's main information security show - a good place for sad security types like me to play with some of the newer toys.
They give away little perspex boxes full of granulated drives - as geeky freebies go, its not a bad one, though the quality of give-aways in recent years has fallen badly...
wylie
Sat May 01 2010, 04:07PM
wylie Registered Member #882 Joined: Sat Jul 07 2007, 04:32AM
Find a use for your HD granules yet? A coherer maybe? Sounds like the crappiest giveaway ever. Keychains were too expensive? LED flashlights? Nah, we'll go with ground up metal-garbage. Wait, what?
