  • Guests: 32
Alexandre (32)
05/07 a.gutzeit (63)
05/08 wpk5008 (34)
05/09 Alfons (36)
Variac Amperage?
Tue Sept 12 2006, 08:51PM
Only 80A max on your 240v line! Wow, where I am the older homes have their (single phase) 240v line fused (or breakers) at 100A, all the new homes (20 years or news it seems) have their 240v line fused (or breakers) at 200A! It must be the area.
Marcus Wagner
Tue Sept 12 2006, 08:53PM
Marcus Wagner Registered Member #486 Joined: Sun Jul 09 2006, 01:18AM
well, I got it from ebay for about 5 Euros...... it was working properly at first but on some day it felt down to the floor... I never saw the crack until now...
but there is one more thing... since the terminals broke off, I simply soldered hot& neutral to the endpoints of the variac, effectively shorting 5 turns each together to make a spot great enough to solder the wires to.... was it my failure by shortcircuiting a few wires on each end? I though this would only effect the voltage availabe but produce no shortcircuit current... ouch!
Reaching
Tue Sept 12 2006, 08:56PM
since i build a complete 5A variac by myself i know whats going on with your variac. in my homemade variac i had the problem that the brush shorted some windings of the variac which got very hot in a few seconds,. maybe its the same with your variac, . look at the brush and at the surface where the windings are blank, search for black sprinkles or shorts, maybe you have a short somewhere.
Wed Sept 13 2006, 10:55AM
I'm pretty sure that shorting those two lots of 5 turns together is what is making the thing overheat.
