  • Guests: 45
Alexandre (32)
05/07 a.gutzeit (63)
05/08 wpk5008 (34)
05/09 Alfons (36)
[fullbridge] mosfets dying, why???
c4r0
Mon Apr 24 2006, 09:06PM Print
c4r0 Registered Member #151 Joined: Sun Feb 12 2006, 02:53PM
Hi,
I'm trying to build a fullbridge SSTC. I have a setup of 12 IRFP451s (well, now it's only 10 mistrust ) on a hudge heatsink (but i'm using only 4 of them):
1145910895 151 FT0 Dsc07961x
This is my gate driver:
1145910938 151 FT0 Dsc07959x
GDT: 5 x 20turns
Schematic:
1145910895 151 FT0 Fullbridge
Here a scope screenshots (5V/div , f=300kHz):
1. GDT secondary, no load
1145910895 151 FT0 Dsc07955x
2. GDT secondary, tiny 12V 1W lightbulb on load (about 120 Ohm when shining)
1145910895 151 FT0 Dsc07956x
3. GDT secondary, 2nF cap on load
1145910895 151 FT0 Dsc07957x
I connected this primary coil (8 T):
1145910895 151 FT0 Dsc07958x
and started increasing voltage with a variac. When i reached about 100V two of the mosfets died (they didn't even get warm neutral ). Secondary resonance freq is about 400kHz. So why the mosfets died?
Before it happend i connected scope to not loaded bridge and noticed that there is some ringing (i dont have a scope screenshot unfortunately), what is a bit strange to me (becouse of no load). There was also little current pulses on power supply.
Please help me! Unfortunately, I cant afford killing mosfets one by one before it start working. frown
BTW.
Steve Ward wrote on his site (mini SSTC):
"I removed 2 primary turns for a total of just 4 turns. This surprisingly helped with heating problems of the MOSFETs!"
How it's possible that removeing turns can cause less mosfets heating? And is it bad that i'm using as many as 8 turns?
Mon Apr 24 2006, 10:19PM
Lower your res frequency. Discrete drivers add some signal delay. Why using darlingtons?
Steve Ward SSTC was a pulsed one.This helps too.
I dont know an explanation. Maibe if the inductance decrease, then the dI/dT in the circuit will be higher and the FETs will stay lesser time in the liniar region? I dont know....
Mon Apr 24 2006, 11:00PM
One thing to check is to see if you are getting voltage break-down between MOSFETs on the heatsink. I believe the MOSFETs you are using have tabs which are "hot" and although you are using insulators, you may be getting a break-down. Just one thing to check.
cjk2
Tue Apr 25 2006, 02:21AM
I'm sure you would have already checked, but are the transistors in the bridge in correct phase?
Hazmatt_(The Underdog)
Tue Apr 25 2006, 02:41AM
Question: Your H-bridge confituration, does it have any Source or Drain resistor to equalize the current differences between device to rail?
If the case is no, one device is almost certian to pull more current, and will die.
williamn
Tue Apr 25 2006, 03:03AM
williamn Registered Member #55 Joined: Thu Feb 09 2006, 04:56AM
I have never used any such load sharing resistors in my H bridges and they do not die, I don't think I have heard of anyone using them either. Sounds to me like your gate driver might be suspect. These type of drivers are a real pain to get working. Try getting your secondary Fres as low as possible. You can try adding some deadtime by sticking in a fast diode in parallel with the gate resistor (K facing away from the gate).
teravolt
Tue Apr 25 2006, 04:48AM
If the mosfets have the same batch number for mosfets and or if they are mached you may not have to use resistors. in genral a low resistance in the emiters or collectors of .1 to.3 help sharing. unfortunatly this may not fix your problem.other things to do is make shure there are tvs's between the collector and emitter and a good zener circuiut on the gates. Good luck
Marko
Tue Apr 25 2006, 08:24AM
I got almost the same waveform when I used H-bridge of bipolar transistors as driver.
I used ICL7667's to drive them directly, and got somewhat better waveform (at 2nf load there was really no such large transistent, but it did apper on 10, 20nF loads and it was too high to run IGBT's fast (another story).
It seems you can't really drive, evnen darlingtons, from 4049IC.
You need something that can provide higher peak current, it doesn't need to be much, if you are already driving it from oscillator you can use TL494. It can deliver significant peak current, it should be even able to drive the bridge alone.
And it will definitely provide high enough peak base current for bridge to swing even far bigger loads.
Also you should wind your GDT for less leakage inductance. Try using few 0.2mm litz wires together, for each winding, solder about 3 or 4 together for each winding and then use motor to wrap then tightly together (I used a lego motor with a wheel) to make tough rope-form of litz wires. Then just wind it like a single wire around a GDT core.
I greatly reduced leakage inductance with it, makes almost no difference between primary and secondary GDT signals.
good luck!
Tue Apr 25 2006, 11:34AM
wrote ...
Just a note that MOSFETs do not have emitters or collectors. The correct names are Drain and Source.
c4r0
Tue Apr 25 2006, 01:01PM
There is no break-down to heatsink. These MOSFETs are in insulated casings. They are also in correct phase.
You are talking about the gate driver, but whats wrong with it? The scope screenshots looks good, isn't it?
I'm using darlingtons becouse they were laying around in my bench. As an oscilator i'm using a function generator.
What about ringing on a not loaded bridge? Is it normal? And maybe I should try a half-bridge first? What do you think? I can't make a new secondary, probably until ... June cry
