Registered Member #63
Hi all,
For my PCB work until recently, I've had the most reliable setup of boiling ammonium persulphate in a Corning Vision glass pan on a gas stove. Hot etchant, clean, crisp traces on the copper.
Unfortunately, I didn't bring my pan with me to Europe. The manufacture of these flame-compatible saucepans ceased decades ago, and they're hard to find on eBay or expensive to ship from the USA.
Does anyone have experience with PTFE-coated pans or pure aluminium? Can the oxide layer resist the etchant? What about 'ordinary' Pyrex baking dishes; will they promptly explode on exposure to flame?
Registered Member #1721
Hello:
Although the following is based on knowlege from the "Grapevine" it does seem to be supported in real life:
Corning a while back developed some types of "super pyrex" very high silica glasses. The purpose was to develope types of glass which could withstand sudden extreme temperature changes like quartz, but which could still be fabricated, and worked, via conventional glass fabrication means. Vicor is an example of such a glass for scientific application.
The Corning Visions cookware is a common example, although some folks claim it is nothing but Pyrex? This material does seem to be slightly more resistant to extreme temperature changes than pyrex in my personal opinion based on my cooking experience, but I am no expert here.
My advice would be to try to use Pyrex, if you cannot find the other glass. Pyrex with some type of heat spreader should be fine. This is done in the lab by using a wire mesh/asbestos screen between the bunsen burner, and the flask.
Today of course we do not want asbestos anymore, but we have replacement materials. I have used Pyrex baking pans directly on electric stove elements with no problems. I do however ramp up the heat in a gradual manner. So if you have gas, you might try a SS wire mesh screen, with the flame turned down a little, or some other heat spreading device, like a ceramic plate.
The key to not breaking any heat resistant glass, is doing things gently, and in a gradual manner. I would stay away from PTFE coated Al, there are always micro-pores in the coating. S.Steel would be a better option then, you could try a small amount of SS to see if it holds up.
I have not used Ammonium Persulfate, so I just do not know much about it. Does it work better than Ferric Chloride for PCB etching? I am curious also, because there are cheap consumer products here like concrete cleaner for example, which are Ammonium Persulfate based. I may give these a shot in the future then.
Thanks Intrawinding for the suggestion of eBay UK and the clever search string, Bored Chemist for keeping me on the straight and narrow, and LutzH for the insight.
Ammonium persulphate was the first etchant ever available to me and I had good results. I've done only a few boards with ferric chloride and while I couldn't compare undercut or trace fidelity, the cleanup leaves a lot to be desired!
Hence "if it ain't broke, don't fix it" - the glass really did perform well with the etchant. That 7" one will at least get me going! I've nabbed it for GBP6.50. Easy!
Registered Member #2261
What a bargain! The wonder of eBay
I thought it was a glass ceramic, but it's hard Googling the transparent amber stuff rather than the earlier white translucent stuff.
You can certainly stick a pan of cold water straight on a full flame gas ring without a second thought - no need for any special care there, but boiling over is a problem as the thick 'glass' holds a lot of heat and keeps things boiling well after you take it off the heat.
In fact anything thermal you can do with a metal pan seems ok, but obviously it's better to err on the side of caution. My last one survived all sorts of thermal abuse I'd never try on normal lab borosilicate, then it broke when I caught the pouring lip on something solid.
