Registered Member #3888
Ha. I've been salvaging gold over the last week too. I've been throwing any gold plated bits (just contacts and pins so far) into concentrated nitric acid and letting it do its thing. when i notice it's not reacting anymore, i add some more nitric acid and wait. when it's all done it looks like either blue or black goldschlager depending on the contaminants in solution. Then i siphon out the liquid, being careful not to suck up any of the gold flakes. Usually some other gunk is left so i add water to dissolve it, let it settle, and siphon out the liquid again. repeat until the liquid is clear. I imagine you could use circuit board etchants to do the same thing, provided that your gold scrap components have a copper core and are free of solder. Certainly doesn't yield as pure of a result as precipitating the gold, but if you just want a vial full of gold flakes, it gets the job done. edit: vile to vial
Registered Member #4181
careful ferric chloride echant can and will dissolve gold when the ORP gets over 600 by the addition of acids, and all those little wires connecting the silicon dies to the package are usually palladium silver alloy in the cheaper chips because gold does not bond to Al because of the formation of “purple poisonâ€, like memory and the the average run of the mill, super cheap IC's, you will not be able to dissolve anything made of or alloyed with more than 10 percent sliver using chlorine based reagents, and even at 10 percent it has to be strongly agitated to remove the passavation layer of silver chloride....
Stick with Nitric or smelting followed by copper electrolytic refinement when dealing with electronic scrap. I generally just grind all of the electronics scrap in a hammer mill to -60 mesh, separate all of the heavy metal components over shaker table with a magnetic trap. I then smelt it under borax flux adding silica until all of the remaining iron is locked up as sodium Iron borosilicate of course you will lose a volume of the silver Dependant on the manganese content of the electronics as stable sliver manganese borosilicate, this usually yields a nice iron free copper bar that can be refined in a .5 micron anode sack with a copper plate cathode, in sulfamic acid (dry-loc from home depot), at just enough voltage to get a suitably high current density, of upto 100ma/cm and not any more, the muck remaining in the sack is dissolved first by nitric acid then Aqua Regia until only oxide residue remains, that can be added back to the next smelt, the yields of this process are much higher than any hydro only process, it just so happens that the majority of the values are occluded by plastic coatings.
