  • Guests: 26
Colin 99 (53)
05/14 hvguy (41)
05/14 thehappyelectron (14)
05/14 Justin (2024)
MOT probs
Omicron
Sun Feb 12 2006, 10:55PM Print
Omicron Registered Member #131 Joined: Fri Feb 10 2006, 09:25PM
I have just gotten a microwave and riped it apart cheesey I have one qustion though, how do I use A MOT? confused All help will be apreciated
By the Way, I will Be on Vaation For about a week so Please nobody mark me inactive.
Michael W.
Sun Feb 12 2006, 11:04PM
Michael W. Registered Member #50 Joined: Thu Feb 09 2006, 04:07AM
hah, how about... Link2
Mabye you should do something safer....MOT's are very high current (lethal)..... If not, good luck!
Omicron
Sun Feb 12 2006, 11:07PM
I Am very good with this sort of thing I have been dooing I sence I was 12. If you are not going to help then do not post
Michael W.
Sun Feb 12 2006, 11:10PM
Ah, heres a diagram of what I have..... Link2
Many MOT's are different so you sort of have to test for what you have....
Omicron
Sun Feb 12 2006, 11:13PM
thats close to what I have so I Wil try It THANKS MAN
Mon Feb 13 2006, 12:13AM
Just a couple f things needing pointing out...
1. MAKE SURE TO GROUND THE CORE (that bolt where the secondary attaches is a good place to do this). If you do not then the core will have 2.2kv on it, as well as anything melt attached to it. Also because the primary winding was not designed to handle the high voltage you can get arking to it, which can in turn connect the high current from the mains in in series with the hv out, providing a very deadly situation.
2. Make sure to use some type of ballast. If you do not use a ballast it will overheat and you won't have a mot anymore.
Also, there probably will only be 1 hvout, so don't spend too much time looking for the second one.
Be safe and have fun :)
Mon Feb 13 2006, 12:38AM
wrote ...
Very carefully.
Remember that a MOT is a LETHAL device. It is not like an NST. If you get shocked by a NST, you'll likely live to see the next day. One mistake with a MOT, and it will likely be your last. They are not current limited and should you get shocked by one, thats 2100VAC with practically nothing to current limit it. Almost like a mini pole transformer.
Seems like everyone here is providing info to your response, but no one has asked the obvious . . .
What will you be using it for???
Part Scavenger
Mon Feb 13 2006, 03:40AM
I got shocked by my 4 stack once. It was about the most awful experience of my life. Keep that in mind when your using these things. Luckily, I must have hit the switch with my hand and stopped it. Burned a nice DEEP hole in my left thumb and a long line down my right palm. It hurt for weeks. Not to burst any bubbles, just be careful. I'm really lucky I'm still around.
Omicron
Thu Feb 16 2006, 01:18AM
IMMMMMMMMM back! and after trying it Nothing any sugestions?
Thu Feb 16 2006, 01:44AM
Omicron wrote ...
Omicron,
Please provide a little more information when you post, this way the rest of the group here has a better idea of what you are attempting to do, and what problems you may be having. Most of members here will go out of their way to address your concerns, and answer your questions, however without a clear idea of what you are trying to do, its very difficult for us to help you.
Remember, if you expect members of this group to take the time to help you, then you should take the time to clearly state your intentions and inquiries with as much information as possible instead of simply posting, "I'MMMMMMMMMMM BACK - I tried it and nothing"
Thanks
Dan
