  • Guests: 24
05/27 Daniel Davis (53)
05/29 Zonalklism (33)
05/29 Dr Hankenstein (67)
Large DRSSTC [update]
Linas
Mon Apr 13 2009, 02:06PM
Finn Hammer wrote ...
I wish I could understand what those 2 BS170'es are doing......
Tdon delay (but not tdoff delay)
two BS170 doing same as if i use on 3K resistor ultrafast diode, like then you driving IGBT, put on 10R 1N5819 or similar cheesey
1240036575 1143 FT66676 P1490532
i have problems with feedback. i madded small 100W induction heater from my last GDT driver, signal from CT was very strong, and burn out all my resistors (2W 1K)
what to do ?
Mon Apr 27 2009, 05:52AM
Excellent work so far... just a couple thoughts:
The RCD snubbers may in fact not help provided you already use the de-coupling capacitors at the bus bar connections (it depends on inductances, but your RCD will almost always have more L than the single cap). But, the snubbers do look very well laid out, good job there smile. It cant hurt really smile.
Second, i suspect you will need more like 2500-3000 Apk for the power level you are talking about at only 311VDC.
How does your de-sat protection work? Is it not detailed in your gate driver schematic? I have wondered whether or not desat protection would help much for DRSSTCs. I think your best bet is to overdrive the gates so much that you are well clear of desaturation risks during normal operation. If you somehow get an inverter fault to ground or something, then your de-sat circuit would be able to save the day, which i cannot say about anything ive designed, so in that respect its good. You have to softly turn off the IGBT for proper protection, though, otherwise the resulting voltage spike might contain more energy than your snubbers can absorb and you blow the IGBTs... at least thats what most power engineers claim.
Linas
Mon Apr 27 2009, 02:39PM
Hi Steve
Over current protection based on MC33153, i connected just signal input, desat input, desat output, and have some 10K load on MC33153 output just in case.
every thing is simple. MC will know then IGBT are desaturating to much, then it 1 in fault out, that signal i will take with isolator (TI, 5ns delay ) and connect other isolator side to LM311 output, 555 input. It will work same as CT. So desaturation protection turn off igbt, but it don't let continuous operation some time. ( that is problem, i can start resonate...)
For Ipeak, i still can't get capacitors for large peaks currents. I want to use 0,5uF or so.
Now have just 150nF and 6KV ill
BSVi
Mon Apr 27 2009, 05:15PM
BSVi Registered Member #1637 Joined: Sat Aug 16 2008, 04:47AM
what to do ?
The more turns of wire you have on your CT, the less power you have to dissapate with your resistors. I think, 1000turns would be enough for your.
Linas
Mon Apr 27 2009, 05:28PM
BSVi wrote ...
yep, if you are using 1:33 >>1:33, but i don't want to use two cores, it will give some delay. But if i use 1000t on single toroid, it will have enormous L :(
I found bug in circuit. Feedback was same as SSTC, so i replaced 1K to 2R2, it forks just fine :)
Also I want to say thanks to Finn, he give me brass bolts, thanks a lot smile
BSVi
Tue Apr 28 2009, 08:18PM
Steve wrote (Link2
I should also mention a bit about current transformers. I read a paper that basically said, for RF use, cascaded (1 CT feeds the next CT) CTs are better than a single CT with lots of turns on it. This makes life much easier! For my DRSSTC-1 using primary feedback i use 2 cascaded CTs, each a 1:33 ratio. I use an identical set of CTs for the over current detection. It seems to work great. One other bit of crucial information. Terminate the CTs (either it be the diodes on the feedback CT or the resistor on the OC CT) as close to the board as possible (i mount the resistors/diodes right on the PCB). This greatly helps reject noise on both circuits.
Dont worry about delays. You are building big coil, and big coil resonates at low frequency, so delays are going to be negligible.
Tue Apr 28 2009, 08:35PM
Linas wrote ...
BSVi wrote ...
Delay? The capacitances of the windings themselves are quite negligible and do not cause any delay in my opinion.
Linas
Wed Apr 29 2009, 05:14AM
5-30ns it's lot mad
i guess that my circuit (with IGBT) can give more than 800ns delay ill
also i think to wind on single toroid 200-300T for feedback, i know who have winding machine, so isn't problem for me :)
Linas
Mon May 18 2009, 04:03PM
Here is interrupter. two 555 for bps and on time control
Principal: Link2
for signal transmitting i think to use fiber optic. also thinking soft bridge turn on trigger on interrupter panel. I don't think use variac, because it is lot of weigh rolleyes
1242662595 1143 FT66676 Img 2424
LithiumLord
Mon May 18 2009, 07:01PM
Err,why no 556? ;) Nice board anyway :p
