  • Guests: 22
  • Members: 1
wpk5008 (34)
05/09 Alfons (36)
05/09 Coronafix (51)
05/09 AmonRa (44)
Please tell me what kind of capacitor is good to use for making EMP
Gratitude
Mon Feb 02 2009, 01:22AM Print
Gratitude Registered Member #1702 Joined: Wed Sept 17 2008, 10:14PM
Please tell me what kind of capacitor is good to use for making EMP?
Your Sincerely
rp181
Mon Feb 02 2009, 01:29AM
pulse capacitor's..... Do you actually know what your doing?
Hon1nbo
Mon Feb 02 2009, 04:06AM
Gratitude wrote ...
Your Sincerely
really do consider the acronym "EMP" (ElectroMagnetic Pulse)
unless you are asking a question such as "should an oil filled HE pulse capacitor or a bank of smaller value, higher voltage capacitors be used?
Shaun
Mon Feb 02 2009, 05:59AM
Your best bet would be a bunch of very high voltage (15kV+) capacitors in the nanofarad range, set up in a Marx Generator. With an antenna, these are capable of producing an electromagnetic pulse.
Gratitude
Mon Feb 02 2009, 01:42PM
with all respect to all of you, regarding answering my question. but i want to use this project as a research and in good way. cause i'm researcher. do you know that this EMP can destroy the kidney stone and help people so please be optimist.
secondly please tell me is it good to use like bunch of 400V,6800MFD cap or its better to use the low capacitence capacitor but high voltage? or is it depend on energy which capacitor is making or the voltage?
Your Sincerely
Thanks alot
aonomus
Mon Feb 02 2009, 01:49PM
If you are a researcher you should have access to IEEE papers or other peer reviewed journals, and you should be able to use the search function on the forums to find previous threads regarding EMP's and you should be able to see that people won't touch these kinds of topics with 10 foot poles at times.
To be frank, 4hv is not neccessarily a forum for us to do your homework for you, read more threads and come back further educated...
Gratitude
Mon Feb 02 2009, 02:06PM
again with all respect there was nothing i found, and thats why i opened this Thread. and i told you this is the research and is not home work, you better be optimist as i told you, and google something then you will understand there is no specific related information in this forume and specially in this section regarding what i asked. so you are welcome if you know something.
thanks again
likewhat
Mon Feb 02 2009, 02:08PM
likewhat Account deactivated by user request on 6/11/2009.
Registered Member #1071 Joined: Fri Oct 19 2007, 02:13AM
To generate EMP you need to fire a fast risetime pulse into an antenna. the frequency (and therefore 1/risetime) of an LC circuit is like (LC)^(-1/2). You need a very low inductance and very small capacitance for that to be a big number. Very small capacitance sucks because there will be no stored energy. The fast risetime machine that I work with uses a 20 nF capacitor that is charged to 50kV. That is kinda hard to do because you need a charging supply that goes to 50kV. That goes through some high pressure peaking switches to get the risetime to less than 1 ns. That could in principle be sent into and antenna and radiated, but I dont know if it would do much because the stored energy is so low.
big5824
Mon Feb 02 2009, 02:12PM
yes we seem to be answering the same question at least once every day or two at the moment....
Gratitude
Mon Feb 02 2009, 02:18PM
thanks again, but as i worked in coilgun and boost converter, i think if it is depend on the energy that capacitors will make for us. why would we use the same thing and use antenna instead of coil to radiate the energy? and secondly we can use good switches to do that risetime which should be less than 1ns.
thanks
