SSTC Project
M3mristor
Sat Nov 08 2008, 02:48PM
Registered Member #1738
Hello all,
currently I am working on a solid state project. It took some time but now gatedriver and gdt work well. I use a fullbridge topology running at a fixed frequency. The next step will be to build a secondary feedback circuit. To avoid problems I will try to use something like a backbone that limits the maximal on time of the igbts. If it works I will post what I am thinking about in detail.
One thing I need to know: How much will the resonance frequency drift when the coil starts arcing. And in which direction? Is there a way to minimize this frequency change, perhaps the geometry of topload? I don’t have the possibility to measure this.
I also wonder if things will work when the bridge´s output is connected to a transformer and then the transformer secondary connected between to lower end of a teslacoil and ground. Has someone ever tried this? I have some large powerferrits here, but I am a little bit afraid of blowing my work.
Thanks for any comment
Registered Member #95
Hi,
I've never measured frequency drift of a coil, but I doubt it's much more than +/-10%. Bringing objects close to the topload lower the frequency, as this increases the topload capacitance somewhat.
The isolation/step up transformer method is called "base feeding". Covered here. It hasn't been used too often, and I can't recall a single "finished" TC which uses that manner of driving.
