Registered Member #1577
I'm sorry but i have looked every where for hours but i couldn't find anything.how could i make a mini emp for a school project.If i can't make a mini one whats the smallest i could make one.how much would the cheapest emp be.any links.Thanks
Registered Member #27
I assume this is just to demonstrate the principle. I suggest you use a capacitor and a triggered spark gap to generate a pulse that you pick up some distance away with a schmitt trigger like a 74HCT14 connected to a simple antenna.
Bjørn wrote ...
how many volts and F would the cap need.Whats a triggered spark gap.finally how would i make one that could actuly wreck something, even if it is 5cm away.(just for a science project not a wmd).
You need high voltage and low capcitance and a very fast risetime. Most 4HV members have failed to wreck anything using an EMP so I would not consider it a realistic project.
Registered Member #902
I managed to set off over-voltage protection circuits... it was a BATTERY powered TC I was building (no connection to mains), and I did not know why the gap would not fire I took the secondary off and fooled around with the gap size and tap... then the gap went off once, and the LCD TV a few feet from me went off and back on... then it happened again when the gap fired again (after having to reset the NST and Inverter in the power supply)
I would not recommend trying this as it is far too unpredictable.... plus you would have to pay for anything you destroyed...
Registered Member #30
Make a Marx generator. Lots of info about those on the web, and they're known to destroy electronics at random if you're careless about grounding them.
Registered Member #1822
It would be next to impossible to destroy a cheap electrical device. The smaller the transistors the more likely it is to fail. Try a cpu. They often fail if you look at it funny.
