Registered Member #1591
Here is a simple (early version) of a homemade CRT that I made over the period of several days. It consists of a 250 ml vacuum filtration flask as the target chamber, a modified test tube as the electron gun, phosphor from a fluorescent tube, and a GAMMA regulkated HV supply. Vacuum is supplied from a two statge Yellojacket vacuum pump. The magnetic deflection consists of two solonoids and currently there is no focus anode (yet to come).
I have attached a couple of pictures and a link to a very quick and dirty youtube video of the project. Also linked on the youtube video is Nyle Steiners "Vial" CRT's. All are quite interesting.
Registered Member #540
Ooo, really cool. I noticed that in the beginning you just kept the spot in one place which burns the phosphor. You can see that it's burned when you sweep over it because it's not lighting up as well. Just keep the intensity down when it's a dot and you should be fine.
Registered Member #260
aonomus wrote ...
Wow, never would have thought of using a filter flask.....
How did you transfer the phosphor coating from fluorescent tube to flask?
From what I have read in the past, you can mix the phosphor coating from the fluorescent with water (I think) and leave it sit in the bottom of the flask. When the water evaporates the phosphor is left behind and coats the glass.
I may be incorrect, though. I am just working off of memory here.
Thanks all for the comments.
Since I have built the thing, I have noticed a major flaw which has greatly reduced its operability. Sputtering. My glass electron gun became seriously cluttered with copper deposition. Thus, the beam current began to skyrocket and the gun began to get hot. Also, as predicted, the beam intensity slowly dwindled to a very faint dot. The remedy is to build a new gun with an aluminum or stainless steel anode and cathode. That would be about a one day project since the target chamber can be separated from the gun chamber via the homemade flange.
Reign was right. Once the phosphor is collected from the donor tube, just mix it with a little distilled water, get it to settle on your chosen face plate in a uniform manner and let it evaporate.....SLOWLY. Dont try to accelrate the drying process. It will surely flake and look messy. Furthermore, a little goes a long way. What may look like a very opaque to transparant film when wet will dry to a nice solid white facing when dry.
I suspect that if you mix a very VERY small amount of copper salt (copper sulfate?) with the phosphor, it will glow blue as opposed to white. Something to experiment with.
Specific to the vacuum, I guess its hovering around 20-30 microns.
Once I have a stable design, I'll hook up the signal generator and post another video. Right now, I am trying to reduce a jpg to a suitable size for posting.
Registered Member #1497
For the electrodes you could try taking the emissive coating off of fluorescent tube filaments and using that to dope the filament that you are using maybe.
