etching
Mon Jun 23 2008, 10:28PM
Registered Member #96
hi, this is my first attempt at UV PCB etching using an HD-DVD laser. Enjoy! :) FWIW, the amount of hassle fromnot having a heated etching bath is considerable. the solution is a few surplus low value finned resistors and some thermal paste or pad, on the underside of the container used (in my case I used plastic but this is a bad idea due to the likelihood of melting)
regards,-A
