  • Guests: 8
Matthew T. (35)
Amrit Deshmukh (60)
05/04 Matthew T. (35)
05/04 Amrit Deshmukh (60)
05/05 Alexandre (32)
My 4Mhz amplitude modulated audio sstc
Reaching
Mon May 05 2008, 05:45PM Print
a while ago i thought that i had to start something new. drsstc design is great but after 12 drsstcs i said "hey, what am i doing here.?" so this was the day i started reading. richies site and his 4mhz sstc project made me thoughtfully.
but i wanted something new, something cooler. so i started reading about amplitude modulating. well, here it is.
In detail its just a basic Class e amplifier like richie burnett used. i simplified his shematic and played around and this is what i came up with.
1210008686 76 FT0 Basic
the 4 mhz class e part works great and at the moment i still think about the idea to get rid of the big transformer for the audiosignal. unless it sounds really great.
this was the first test of the prototype, so its all really basic.
what i want to try is to use a linear regulator like everyone here knows, for powersupplys etc. the linear regulator is set to around 90% of the input voltage. with a smallsignal amplifier the audiosignal is amplified and then fed to the gate of the linear reg causing the output voltage to change. like this.
1210009185 76 FT0 Basicam
in theory i should have a output voltage which isrelatively stable over a wide current range with a modulated audiosignal on top of the dc voltage. in my simulations it all works really great and with the amplification factor and output voltage carefully set, the power dissipation should be less than 30Watts for 120Watss output power. my first tests showed me that the class e part works best with an input voltage of around 50 volts,.
im on holiday now, so this project will be updated as soon as i tried this linear reg. for sure, the shematics shown here are just for showing what i mean. the final circuits are much more complex.
Mon May 05 2008, 11:01PM
Sounds like a great project, you should be able to get some really nice sounding audio out of it with such a nice high Fo. It is hard to judge audio quility from a youtube video, but it sounds like you have some kind of nonlinearity in your system (saturating the audio transformer?) that is causing some distorsion.
I hope you can get the liner reg to work!
Tue May 06 2008, 10:50AM
You'll need some kind of RF bypass capacitor between the output of the modulator and the primary coil of the Class-E stage. It's hard to see how it could have worked well without one.
Reaching
Tue May 06 2008, 11:20AM
mh, maybe i was lucky with the settings. this is my first class e project, so what kind of rf bypass capacitor do you mean? a cap in parallel with the primary, tuned at resonant frequency? ok, the mosfet got warm in my circuit but i ran it for some hours and nothing bad happend. input voltage is around 40-50volts but i tested 100volts as well. sure, the design is not perfect, but for now it works fine.
maybe someone who already build class e stages can give me some hints to improve my circuit.
well, there was some disortion due to the audio transformer in my previous circuit. the dc current flowing through the transformer caused the transformer to saturate very quickly, and maybe the bad quality of the selfmade mosfet amp caused more disortion.. thats why i try to get rid of it with this linear reg design. today i want to build it and do some research and tests with different loads to see how rugged it is and how much power dissipation i have to expect.
theres still a lot to do, and thats why i thought to open a project thread to get some suggestions from you
Tue May 06 2008, 06:48PM
I think that he means you need to add a cap from the v+ side of L3 to ground, because as it is the inductance/resistance/losses in general of the audio transformer is being added to L3.
The size for that cap is tricky because having too large of one will kill the high frequency performance.
Also, something that would be interesting to see would be to run this coil strait off of a 'real' audio amplifier. If you coil is drawing 100w at 50v that is 25omhs of impedance--which should be able to work with an audio amplifier without too much trouble. I suppose the biggest problem would be dealing with the nonlinearities of the coil, although it should be possible to inject a DC bais after the dc blocking cap in the amp, although by the time all of that is working it would probably have been easier to just build your own modulator they way you were planning....
Tue May 06 2008, 09:07PM
Awesome, I'm looking forward to seeing what you come up with!
Sorry, but no constructive criticism. neutral
Wed May 07 2008, 10:17AM
Richie Burnett got around all this a much simpler way as I recall -
He just used two class E amplifiers in push pull, and phase modulated one amplifier with audio.
I don't know how he done that, possibly with some sort of crazy PLL circuit.
Power levels and frequencies were of course immense (18Mhz and >1000W with just two IFP460's, I think. Hope I'm not letting out any of his secrets here confused ).
I don't know much more than that but apparently it is not really worth trying to use some kind of huge amplifier for audio modulation.
I'm not sure how this phase shift modulation sounds, but it may be suffering from supply voltage sag since there's no feedback of any kind to compensate it.
I hope Richie can explain this better some time,
Reaching
Wed May 07 2008, 01:23PM
well. ive build the linear reg and was surprised.
its really difficult to adjust, but it works quite well. its obviously not that powerful than the audio transformer design, mostly due to the induced extra voltage in the transformer design.
40volts is fine, but the modulation ratio is really small and so on the volume is not as good as i expected.
now, that i know, that this design is worth a try, i want to go further. a new linear reg design for voltages up to 100v is the goal.
after that, the prototyping is almost done and i can start working on my stereo design
GeordieBoy
Wed May 07 2008, 02:54PM
If you want to go down the linear high-level AM route I would recommend investigating the Class-H modulator. This arrangement uses a split rail supply and two linear pass elements to give a very respectible efficiency and low distortion for typical audio signals. The modulation efficiency at the quiescent operating point can be nearly 100% because one pass element is in saturation and the other is in cutoff. Excursions of the audio signal either take one device closer to cutoff, or the other device further towards saturation depending on the polarity of the audio waveform. This situation is a significant improvement on a Class A high-level modulator, but without the complexity of a full-blown PWM switching amplifier.
Some info is here: Link2
(It also doesn't require the special modulation transformer to resist saturation due to the DC flowing in the secondary.)
The dog's bollox of high-level AM modulation is the polyphase Class D switching amplifier, but things like this are difficult for a hobbyist to design, build and set up. Or as Marko eluded there are alternative low-level means of introducing modulation such as FM and out-phasing.
-Richie,
Reaching
Wed May 07 2008, 05:23PM
hey thanks. maybe i´ll try it.
finished the linear regulator prototype and build everything on a larger heatsink.
made a new video with a better cam so you can imagine how well this thing sounds. :)
