printed circuit board -- suggestions
kell
Sat Feb 11 2006, 01:33PM
Registered Member #142
My first time doing a printed circuit board. I've gotta send out a printed circuit to be fabbed that actually has a small 1" x 2" circuit repeated many times on one large board, which I will then score or have rows of holes along which to break it into its constituent copies. I went to expresspcb.com because it looked user-friendly. Drew a circuit and went to copy it to another area on the grid. But you can't position the copy; the program just plunks one down arbitrarily in the middle of the screen. So I think I need to use a different program. Does anyone have knowledge of a program (pc fabbing houses will accept) that allows one to draw a circuit in a small area, then copy/repeat it many times to fill a large board? Many thanks in advance.
Will
Registered Member #57
You can move the copy in E-PCB. Upon pasting the copy it will all be selected, so you can then click on it and drag it to where ever you want.
kell
Eventually I got it worked out.
