Registered Member #1025
jmartis wrote ...
I heard that dc arcs pull longer than ac ones. Is this true? For example if I rectify the output of my MOT will I get bigger arcs?
DC arcs should be much more stable but you need a good choke in series (not a parallel cap!) to see a real difference. The point is tha DC arc generates much higher temperature inside the track and thus you get much longer conductive path...
Registered Member #27
The capacitor goes in parallel to smooth out the ripple of the rectified AC, that way you get DC with low ripple.
If you read the specifications for switches you will see that the DC voltage rating is usually a lot less than the AC rating because of the arcing problem.
Registered Member #152
I would try it but I would need at least 80 3A 1KV diodes to make 20KV bridge rectifier (the output from my dual MOT bank peaks up to 15kV).. not exactly cheap well maybe I can try with just 1 MOT
Registered Member #162
If you rectify the output of your mot with a capacitor across the dc when you try to pull an arc you will be rewarded with a VERY loud BANG as the capacitor discharges almost completely in an instant for a stable dc arc you will need resistance in series, which will make the arc very weak. You could have diodes and an inductor which would be better but the inductor required would be very large to get sufficient inductance that doesn't saturate = not practical.
jmartis wrote ...
I recommend using IN5408 diodes for this purpose and use small (1nf/1000V) ceramic cap with 1,2Mohm resistor parallel to each of the diode. Use twice the voltage ratting of diodes than is the expected voltage you going to rectify. I have an experience with this setup for MOT rectifying and it works well... I think that with bridge setup you should see already some improvement, but the choke made of another MOT is a good idea, however I'm not sure if it survives...
Bjørn Bæverfjord wrote ...
We are disccusing plasma pulling and not arcing which can be aslo the problem of the switches. Otherwise I do not agree , according to my experience the AC sparks for greater distances...
