Registered Member #131
Is it possible to take the output from an ignition coil and make it DC? I need the power to power a x-ray tube. And I know about the dangers of X-rays. It needs to be cheap and simple. Goggle had nothing on this.
Registered Member #56
are you sure you have enough power to run the tube?
In any case, yes you can rectify it. To do so requires a string of avalanche rated (preferably) high speed diodes like sf1600's or uf4007's. Just string enough up to have about 1.5x or 2x the voltage you are producing and put it on the output of the coil.
Registered Member #89
Iggies usualy have few tens of W of output power and voltage hardly reaches more than few tens of kV in best situations. With two of them maybe you could push about 100kV and power a small, really small tube.
The dimmer will work, because it will see an AC current, but the primary of the ignition coil will see only dimmed monoalternances. So I suppose that the output from the iggy will have a bigger alternance than the other, something similar with a HV DC output. This will eliminate the need for HV diodes on the output.
Use about 100 series 1N4007s and bootle caps for filtering. If soldering miles of diodes bores you you can try selenium rectifier (usually 15 -20kV few mA, couple of seriesed MO diodes or maybe vacuum HV diode for such small currents)
Problem is getting such high voltages, try dimmer + 2 coils, you must also insulate everything very well...
If you have DC flyback I think it could do, or 2 antiparalel, without problem. I designed driver that gives about 35kV (single flyback) from 20V input, with little more you can get 40, 50 easily. Just don't know are diodes going to withstand it.
You can never get actual DC from any transformer secondary. Rectifying primary seems rather funny, most probably that way you won't get any output at all.
Registered Member #32
Omicron wrote ...
Where do I get this stuff? Radio Shack? And I am on a budget you no.
It took me very little effort to find this. Please don't ask us to check the RadioShack catalogues for you.
Bear in mind that an ignition coil driven in the usual way will have a very large HV spike with one polarity and a much lower voltage output of the other polarity for the rest of the duty cycle. Exploiting this you don't always need to use diodes to rectify.
Registered Member #30
The X-ray tube should act as a rectifier, so you shouldn't need any diodes, just connect one ignition coil to each end (being sure to get the polarities right) and stand well back
Selenium rectifiers can only stand 26v per junction if I remember right, so they'll surely be far more bulk and hassle than 1N4007s (800v)
If you're on a budget, aren't MSD Blasters a bit expensive? I thought they were special high performance coils for racing engines.
