Registered Member #580
i have about 70 turns of 0.125mm copper wire wound around a 31cm diameter ring. This is then connected to a battery operated 2 stage op-amp preamp circuit and then to my computers audio line in. Im sampling at 96ksps (0 to 48khz can be received) in speclab and here is the resulting spectrum. I can see our TV at 15.625khz as expected but the signal in question is the ~10khz bandwidth one with a center about 34Khz.
... not Russel! Registered Member #1
It is difficult to say. It appears to be composed of harmonics. Any chance I could get some of the raw data, such as a .wav file of the soundcard's input?
Thanks for the file! Always interesting to hear VLF from some other part of the world.
From listening, the signal sounds very familiar to noise generated by a computer monitor or TV set. Try shutting off your monitor and see if the signal vanishes. You might also try shutting off any nearby TV sets. There is also a repetitive broadband pulsing apparent throughout the sample, probably due to CPU noise. An isolation transformer would help with this a great deal (and with some of the 50Hz harmonics), but constructing one that will work at such low frequencies is no easy task.
I also don't see any sign of the military MSK stations in your spectrum, indicating that received signals are probably being swamped by op-amp noise, and the thermal noise in the loop. The level of received stations is proportional to the square of the cross-sectional area of the loop multiplied by the number of turns. If there's any way you can wind the same amount of wire, around a larger frame, say 21 turns at 100cm diameter, you will see a dramatic improvement in the capabilities of your antenna -- about 10dB). A 200cm frame with 10 turns of wire would be an improvement of about 16dB.
no i don't think it is a TV or monitor, the TV was off at the time and we are not using any more CRT monitors. The circuit i used was 2 stages of using a TL074CN
here is another really weird one, unfortunately i don't have a recording. some interesting points: the pattern is repeated exactly the same every minute with the offset changing every minute some of the lines appear to have a binary type doubling distance between them on the time domain. the set of offsets is repeated every 10 minutes.
