  • Guests: 25
Alexandre (32)
05/07 a.gutzeit (63)
05/08 wpk5008 (34)
05/09 Alfons (36)
X-ray :D
Linas
Sat Dec 22 2007, 09:16PM Print
hi
i have very big x-ray tube, and have 200Kv sstc, is it posible make good x ray machine??
and how tu know, how many pm or nm (nanometre)electromagnetic radiation ?
some photos shades
Ray
Shaun
Sun Dec 23 2007, 04:17AM
I'm pretty sure X-ray tubes need DC, not HF AC. Plus they are usually fired by a large capacitive discharge, producing a high-energy burst of X-rays. You will probably get some radiation with that tube on an SSTC, but I doubt it will be significant.
Sun Dec 23 2007, 10:31AM
I don't know how much voltage it needs but 80-100kv is achievable with a DC flyback
c4r0
Sun Dec 23 2007, 12:14PM
c4r0 Registered Member #151 Joined: Sun Feb 12 2006, 02:53PM
I think driving real x-ray tube (especially heated cathode type) directly from SSTC is not a good idea. To get preety good radiograms you need at least 50kV (medical diagnostic x-ray machines usually uses about 50-100kV range). DC would be the best, but actually x-ray tube is a vacuum diode, so it will self-rectify the current. In some x-ray machines (in my x-ray machine too) this self-rectifying is used and x-ray tube is connected directly to the HV mains transformer winding, but it's 50Hz, not hundreds of kHz like in SSTC. Anyway, you can try it, but you absolutely need a geiger counter wink
Linas
Sun Dec 23 2007, 12:39PM
how to detect x-ray in house ?
ConKbot of Doom
Sun Dec 23 2007, 03:55PM
Shaun wrote ...
Some of the X-ray machines Ive seen at work use 2 capacitors, each about the same hight as and 3/4 the diameter of a 55 gallon barrel. amazed
c4r0
Sun Dec 23 2007, 04:33PM
Linas wrote ...
With geiger counter or suitable ionising chamber. I'm preety sure that you can easily find a cheap geiger counter on internet auction in Lithuania, just be patient (i hope you have an internet auction website there smile ). Or you can make one just like Uzzors did: Link2
Linas
Sun Dec 23 2007, 04:51PM
c4r0 wrote ...
Linas wrote ...
I'm preety sure that you can easily find a cheap geiger counter on internet auction in Lithuania, just be patient (i hope you have an internet auction website there smile ). Uzzors did: Link2
cheesey no :(
Sun Dec 23 2007, 09:06PM
Why not? It works okay. cheesey
I've actually been doing some x-ray experiments lately, but so far the radiation has been pretty weak. I haven't seen any fluorescence yet, but my geiger counter will overflow when brought within a few cm of the tube. This is with the 0.4R/h GM tube... At least it proves the geiger counter works, and x-rays are present! If only I had a real x-ray tube and not some crummy HV rectifiers.
As for driving your tube (which you are lucky to have) I think your TC would work alright, at least to see that it works. As said earlier the tube will rectify anyway, and being a tube it can handle the frequency easily.
Wed Jan 16 2008, 11:33PM
Unless they are specifically designed for detecting the low energy X-rays likely to be produced here, GM tubes are not at all a good way to detect them.
X-ray sensitive GM tubes are constructed much like a longer version of an end-window alpha tube, but with a thicker mica window. A heavy fill gas like argon or krypton is usually used, and at a much higher pressure than in other types of GM tubes - typically 600 - 650 torr.
Some 'general purpose' beta/gamma GM tubes will fail to detect low-energy X-rays altogether, and none but those specially designed for the job should be relied upon for a meaningful indication of dose.
Low energy X-rays are the most hazardous to human health, so one can't afford to not detect them!
