Registered Member #256
i dont think this is posible but my friend and i are trying to get a co2 laser going and he thinks we can make the laser tube out of a light bulb. is this feasible, if not, i am sure that most laser tubes are above $100, if this wont work is there anywhere i can get a co2 laser tube for les than that?
Registered Member #229
One major problem is that the output radiation form a CO2 laser is infrared. You need special output windows (alcaline halogens cristals as NaCl, NaI..), the glass will not work. The power gain is proportional with the discharge lenght, so it would be almost nothing for a light bulb. And some water cooling for the discharge tube also.
thats what i was thinking, well he also wants me to handblow glass n stuff, i do not know what to do for this, and i got an oxy acet torch, i assume is hot enough to do though. i think i should convince him to buy a tube but he is kinda hard headed sumtimes
Registered Member #135
I'm teaching myself glassblowing right now. In order to make a precision device like a laser you will need probalby 5 years of experience, glassblowing is that hard! Plus a laser will require quartz windows and you need a hydrogen torch for that because of the quartz and contamination.
Short answer, you will have to find a premade tube or have one made.
Registered Member #65
CO2 laser tubes are cheap to buy ($25 to $150 surplus)... it’s the support hardware and regulated gas supply that’s pricey. The cheapest functional medical unit I saw was on ebay for $600 US. Mind you one has to be an authorized medical tech to purchase off of some of these sellers (there is more than a few people getting scammed this way.)
Hazmatt, have you tried Pyrex glass yet? Compared to most it can be very unforgiving indeed (5 years I would say is optimistic.) =] lol
Some of the best furnaces can be found in surprising locations. Notably the Art schools have some of the better techniques for handling larger designs. It should be pretty cheap to audit a class for orientation etc. and get full access to the equipment.
The only glass I work with is Boro in fact. And these days its incredibly difficult to find a vendor of soft lead glass tubing. You have to go to a sign vendor to get it.
So far I can do T seals, I'm blowing more bulbs now ...successfully but lopsided. Playing with the torch that is my avatar, making Christmas ornaments, and I'm hopeful to use my Uranium glass to seal Tungsten into some small apparatus for practice.
I want to make a condenser of any type, but I need an annealing oven for that. You would be surprised how difficult it is to do anything without annealing, It means I have to be really good.
Someday I will get a lathe second hand, and then things will get really interesting.
I like tube, round stock, and sheet work. Most of the detailed stuff can be done in cold water with a diamond saw, file, and router. The nice part is most of the stuff is flat or thin enough to fit on a few plug-in smooth surface iron heater lab plates. A 1/2†spun ceramic blanket on top keeps it toasty while slowly dropping the temperature over a few hours. For other stuff there is a local studio that has a furnace in the back and a few old kilns for annealing ovens.
Bulbs / Spheres may be made vertically by swinging to even out the wall thickness (like a pendulum at around the working point.) If uniform size is desired, a glass mould can be made fairly easy and kept heated as mentioned above. If need be a tedious flame annealing can be done on small parts.
A practice project like a simple Erlenmeyer flask would need at least a few steps: pre-heat stock, at working point temperature seal the end, use a mouth piece valve and tube to slowly increase the bulb size wile rotating in a flame, reheat bulb to working point temperature, place inside mould cavity and blow cast while at the while working point, carefully remove item while still hot, roll score tube with file and tap to snap the piece free (fire proof mitt to catch piece), reheat tube end to working point temperature to round off the edges, place on hot plate at softening point to make a flat bottom, then transfer to an annealing set-up. (This is a simplified method that does not require a few transfers.)
