  • Guests: 29
Matthew T. (35)
Amrit Deshmukh (60)
05/04 Matthew T. (35)
05/04 Amrit Deshmukh (60)
05/05 Alexandre (32)
SAQ Transmission - December 24th, 2007 - 0800 UTC
Chris Russell
Fri Nov 30 2007, 07:18AM Print
Chris Russell ... not Russel!
Anyone who hasn't had a chance, get your VLF antennas ready! SAQ will be firing up the historical Alexanderson alternator and transmitting on 17.2kHz on December 24th, 2007, at 0800 UTC. For anyone who doesn't know, SAQ is a VLF transmitter in Grimeton, Sweden, and transmits at a frequency so low that it would probably be audible to most people if it were sound instead of electromagnetic radiation. A radio is not required for reception -- just a big loop of wire, a sound card, and a program like Speclab.
I haven't had any luck with this so far, but Steve Conner was able to get great reception last time, and posted the results here. I'm hoping that my active whip antenna will finally be able to bridge the gap. Anyone else up for a go this time around?
Spedy
Fri Nov 30 2007, 04:22PM
Spedy Registered Member #964 Joined: Wed Aug 22 2007, 12:39AM
This sounds fun. I'll have to see if my sound card will work, and then how to hook it up properly.....
Anyway, thats cool. It took me a bit to realize what VLF meant.
Chris Russell
Fri Nov 30 2007, 08:08PM
Yes, VLF is very low frequency, the name for the band of frequencies between 3kHz and 30kHz. It's a great place to get started with radio in this day and age, since nearly everyone already has the equipment to receive 0-22.5kHz or 0-24kHz. Unfortunately, most of the man-made signals in this range are encrypted data links for use with submarines and other naval vessels -- doesn't make for interesting listening. The bright side is that there are many interesting natural signals to listen for, and once in a while SAQ fires up their transmitter, giving everyone a chance to receive some morse code.
Chris Russell
Thu Dec 06 2007, 12:53PM
Update! The time of the SAQ transmission has changed to 0800UTC. The message will be repeated at 0815UTC.
ShawnLG
Fri Dec 07 2007, 06:35AM
Is this starting at 3:00AM for the US east coast?
Chris Russell
Sat Dec 08 2007, 01:16AM
That is correct. However, the transmitter will be tuning up from 0730 UTC, which would be 2:30am.
ShawnLG
Tue Dec 18 2007, 04:37AM
I am ready! My antenna is a longwire running across the roof of the house. Also, I have also put together a 17.2khz active bandpass filter to filter out most of the other junk such as 60hz mains. Below is a snapshot of Spectran and I am picking up the 15khz horizontal frequency from a TV in the house.
1197952630 286 FT35216 Vlf
Chris Russell
Wed Dec 19 2007, 05:47PM
Looks good! I'll post a screenshot of what I see in that area later this week, so you can see how they compare. At night, do you see any sign of the big military msk transmitters operating on 18.6, 19.6, and 22.1 kHz?
ShawnLG
Wed Dec 19 2007, 08:05PM
This is what I can find around 2PM. I do not know what they are.
1198094756 286 FT35216 Vlf 23khz
1198094756 286 FT35216 Vlf 21khz
1198094756 286 FT35216 Vlf 20khz
Bjørn
Wed Dec 19 2007, 09:42PM
Generally anything that drifts in frequency is unintentional transmitters, usually local. Some times you can clearly hear that it is a circular saw or something similar by just listening to the signal.
The intentional transmissions are usually fairly narrow in bandwidth and at a very constant frequency. This picture show a typical and strong transmission at 18.6 kHz.
6khz Off
