  • Guests: 23
Matthew T. (35)
Amrit Deshmukh (60)
05/04 Matthew T. (35)
05/04 Amrit Deshmukh (60)
05/05 Alexandre (32)
$20 budget sstc
HvHaxor05
Tue Nov 13 2007, 09:34PM Print
HvHaxor05 Registered Member #1116 Joined: Tue Nov 13 2007, 02:11AM
PLEASE DONT MAKE FUN OF MY SPELLING AND GRAMMER
ok i have a few components for a 1/2 bridge sstc here is what i have
4 IRFP244PBF (i guess full bridge is possible
ferrite bead
some 12.2v zenier diodes
555
pots
caps
2 UCC37321P mosfet drivers
1 74ac04pc hex inverter
5v reg
12v reg
2 24v 10A transformers
1 18v 1A transformer
resistors
i have an oscope clamp volte meter exc
my secondary is a 30"X4.5" with 26g wire
CAN YOU HELP ME MAKE A SSTC OR DRSSTC WITH THESE PARTS
i got a $20 budget tongue for extra parts (radioshack or newark if you can)
Shaun
Tue Nov 13 2007, 11:09PM
First couple things I see wrong:
You will need a UCC37322 to go with your other UCC
A ferrite bead may be too small for a GDT.
IRFP244 is pretty small-15A may not be enough even for a small coil, certainly not enough for one with a secondary of the size you describe.
Plus they are MOSFETS, which make a DRSSTC pretty impossible.
AndrewM
Wed Nov 14 2007, 05:56AM
lol, did you guys see his spelling/grammar?! wink
HvHaxor05
Wed Nov 14 2007, 11:12AM
what fets do you suggest and all i have seen for a gdt is ferrite beads also and why do i need another ucc i got 2 witch is enough to drive the GDT
and AM your an ass ;-P
Avi
Wed Nov 14 2007, 01:04PM
Shaun wrote ...
since he has 2 UCC37321's (which are inverting) he can connect the output of the first to the input of the second! (or use a seperate invertor beforehand eg the 7404, which is probably safer since will be unloaded at this point)
Wed Nov 14 2007, 02:11PM
Firstly I dont know about your inverter but use the 74HC 14 variant (because its fast)
Avi wrote ...
If you go this way, you can use one of the left over invertors in your 74HC14.
Wed Nov 14 2007, 03:55PM
UR SPELLING SUX LOL
I'm with AM on this.
Ken M.
Wed Nov 14 2007, 06:04PM
Go digikey IMO. Sorry for the one liner.
HvHaxor05
Wed Nov 14 2007, 08:12PM
i dont think my mosfet drivers are inverting i found this Link2 witch uses the same drivers i would like to use these plans except i do not want a self res sstc because im going to be drawing arcs from it
AND PLEASE STOP MAKING FUN OF MY SPELLING ITS MAKING ME VERY INSECURE
i would also like to state that im 15 tongue but have made spark gap coils for about a year and coilguns for about 4 years
HvHaxor05
Wed Nov 14 2007, 08:24PM
Shaun wrote ...
What mosfets do you suggest (also the power needed to make a good sstc) as long as you keep the price below $100 for an h bridge or if necessary a 1/2 bridge
