  • Guests: 33
05/04 Matthew T. (35)
05/04 Amrit Deshmukh (60)
05/05 Alexandre (32)
GDT Drive Chips
MRacerxdl
Mon Oct 22 2007, 09:13PM Print
I was wondering what these driver chips (TC4449 and UC37322/1) have it especial. I was wondering if I can use the CD4007 (CMOS Dual Complementary Mos Pair + Inverter, see the datasheet, its interessant, it have 2 idependent Mosfets).
I was talking about that, because on Brazil I didnt Found that Chips, for you have some Idea, if I put on Google Brasil, UC37322 I dont found any pages :P
But I Think I can use that 4007, its that true?
Marko
Mon Oct 22 2007, 09:39PM
Not even close. Driver chips need to source very high current (in ampere range) in short amount of time to charge and discharge capacitive load rapidly.
Discrete solutions are possible but rather tricky and not well researched.
You should be able to get some UCC?s from digikey, from some of forum members or from TI as samples (if they'll ship to you?)
Marko
MRacerxdl
Mon Oct 22 2007, 10:12PM
Digikey supports PayPal or something else? or Someone supports that? because its a safe method, and I can use it (I am using to buy a FPGA from knjn) , I will see if a member can send me. Thxx...
Coronafix
Wed Oct 24 2007, 10:02PM
I couldn't find those UCC's here in Australia either, the closest I got are
the TC4420 & TC4429. They don't source the 9A that those UCC's do, but 6A
is pretty close. Try looking for those over there.
MRacerxdl
Thu Oct 25 2007, 11:04PM
I think its easier I made a driver, isnt it? Here I can find all mosfets (including the high current ones, that can handle 300A continuous!), I think the K2049 or IRF540 (+ the P equivalent or other with invert input), with a 4007 it. Its good to make that?
Thu Oct 25 2007, 11:23PM
A 4hv forum user named Reaching made a circuit that you can use to drive a GDT. I could not find it now but i guess you can just ask him.
MRacerxdl
Mon Oct 29 2007, 04:59PM
Hi all, I have found the TC4420CPA here in brazil to buy (yes I found it :D), I see on the datasheet, it can handle 6 Amperes, thats is suficiente for GDT Driving?
Tue Oct 30 2007, 10:48AM
Mestre Racerxdl wrote ...
It depends on the particular device you are switching.
Anyways, you can always parallel gate driver chips to get more current capability. Some people even stack these right on top of another.
MRacerxdl
Tue Oct 30 2007, 03:29PM
I will drive some Mosfets IRFP460 with GDT. I dont know if its Expensive, but on Brazil the TC4420 its R$12 (Arround US$6), the IRFP460 its cheaper than TC4420 here is R$8 (Arround US$4). I will buy some of TC4420 (Its the only drive chip that I found here) and test it.
