  • Guests: 79
RateReducer (35)
11/01 RateReducer (35)
11/02 Download (31)
11/02 ScottH (37)
Electrostatic levitation wand?
Mon Mar 06 2006, 01:29PM Print
This actually sounds plausible, though I find the "levitates indefinitely" part a bit hard to believe.
Anyone else heard of this?
It looks like the majority of the parts needed are available- old fluorescent lighting capacitors have aluminised mylar as the plates and you can get PVC pipe and/or styrofoam nearly anywhere.
-A
Pcnerd
Mon Mar 06 2006, 02:01PM
Pcnerd Registered Member #88 Joined: Thu Feb 09 2006, 02:37PM
you could always try it
parts needed aren't so much
* Tinsel (a thin strip of aluminized mylar about 30 cm long)
* PVC tubing (1/2 inch or 3/4 inch)
* wool (You can get wool cheap at used clothing stores, wash it and dry it well.)
you could always try it...
* plastic drinking straws
* scissors
Mon Mar 06 2006, 02:18PM
I made a similar experiments (electrostatic levitation), using two vynil record discs.Put the discs (one on another) on the table, and rub the surface of the upper disc with a textile (even with bare dry hand), until you hear the crackling sound. Keepin the upper discs only on margings, separate the discs (15-20 cm between them). You can then introduce little alu foil pieces between the discs (better making some blobs from the alu foil, not spherical, but ovoidal, with two conic extremities) and they will levitate between the discs for some time. :)
Keep the disc only on border, do not touch the outer or inner surface.
Bjørn
Mon Mar 06 2006, 03:48PM
Indefinitely is not too hard to believe, it had been worse if it was infinitely. It looks quite fun, remember that things like this works much better in dry air.
Mon Mar 06 2006, 04:17PM
I would think ballancing anything on an charged wand would be very difficult. Does the fact thats the ring has some flext make it easier to keep up?
Bjørn
Mon Mar 06 2006, 04:53PM
Objects that have low density are usually fairly simple to balance because air resistance makes them move slowly.
Alessandro
Wed Mar 08 2006, 10:29AM
Alessandro Registered Member #70 Joined: Thu Feb 09 2006, 08:19AM
I tried it and yep, it works great. smile humidity is your worst enemy, do it in an air conditioned room.
Dr. Shark
Thu Mar 09 2006, 11:29AM
I suppose for the tinsel it would be easiest to slaugher a small metalized film capacitor?
