  • Guests: 17
BlakFyre (36)
SENTRY (31)
04/30 BlakFyre (36)
04/30 SENTRY (31)
05/01 Shaun (34)
It's time for an SSTC
Fri Sept 28 2007, 03:25PM
You want both of your drivers to be off when idsabled so you would have to use a lot of logic there. Both drivers would need to be non-inverting in order for you to be able to disable them with and gates. Then you would need to invert the input of one and gate again.
This is serious complication and lots of unwanted delays. If I had no UCC's I would probably just run CW until I get some. Drivers are pin compatibile apart from enable.
Fri Sept 28 2007, 04:24PM
can you get samples of the ucc's?
Munkey
Fri Sept 28 2007, 06:36PM
Munkey Registered Member #588 Joined: Sat Mar 17 2007, 11:06AM
Yep, from Link2 they have fast delivery so you can blow em' up twice as fast tongue
I did, the only thing which is annoying is that they only have the little SO-8 SMD packages. Have fun soldiering them smile
Fri Sept 28 2007, 07:16PM
Bacon wrote ...
oh cr*p, there's no way I can solder this with a soldering gun tongue
I'll probably have to run halfwave CW, until I find a way how to interrupt the TC's
Zum Beispiel
Fri Sept 28 2007, 07:51PM
If you really need them, why not just buy some? They only cost like 2€ a pop.
Fri Sept 28 2007, 07:54PM
Zb wrote ...
well, the answer is simple.. because I can't buy them where I live and I don't want to pay 5x the cost of the ic's for shipping
Munkey
Fri Sept 28 2007, 07:55PM
jmartis wrote ...
You don't have a soldiering iron? Even with a big tip I still did it. I would still get them, they're FREE!!
ragnar
Fri Sept 28 2007, 11:38PM
Bacon wrote ...
Last time I checked, TI will deliver DIP8, SOIC8 and MSOP8 UCC MOSFET drivers, all of which are possible to solder by hand with a fine tip.
I tried a couple of techniques here:
http://4hv.org/e107_plugins/forum/forum_viewtopic.php?16319
P.S. Please don't over-exploit (exploit) the samples offered by TI. They are NOT 'free'. The samples you might receive are subsidized by the profit TI makes on the same chips that WE pay good money for.
If a group of regular abusers re-orders the chips without a followup purchase, it becomes uneconomical for TI to distribute samples of that chip, and they may stop offering them at any time.
At least try to make a quarter-effort not to blast them all by mistakes like "bumping the voltage knob".
Munkey
Sat Sept 29 2007, 09:44AM
Another way that I found easy is to get some copper stripboard and stick it to that, heres a pic of mine: Link2
Yes, I know it is wrong to exploit their free samples, the chances are that next time I am going to buy them along with a some other stuff.
Experimentonomen
Sat Sept 29 2007, 11:23AM
Thats why i sample the dip version tongue wink
