Registered Member #187
A coulple things to watch out for if you decide to build a VDG:
Belts that are very elastic will severely limit how fast you can run the belt. They have a terrible tendency to come off the rollers, possibly causing damage to other parts. They also tend to oscillate inside the column, sometimes to the point of slapping which can create a grabbing effect.
As long as you have means of controlling the motor speed, you can avoid these problems by just slowing the motor down. Vacuum cleaner motors run ridiculously fast compared to induction motors.
Registered Member #229
If you use a collector electric motor, put it in an enclosure. The fine carbon powder from the carbon brushes can affect the dielectric properties of the belt.
Registered Member #98
well i'm most likely going to be using some kind of a rubber belt (any suggestions where i can get one for either cheap or free? ) and I WILL have a fan switch or some kind of acceleration control dial on it just in case a vacuum cleaner motor is in fact too powerful.
Registered Member #79
Tips:
The faster the motor the better until you hit 5000 rpm IIRC from a book("Lightning Bolt Generators" - Lindsay publications). I used a belt sander as one pulley, the middle part of a bicycle wheel (pull out all the spokes, best top pulley around I know of). I used the liner out of the wheel for the belt and later part of the innertube, it worked pretty well. If I did it all over again, I'd find something a little less rubbery. Maybe a piece of treadmill? Work hard or your brushes, they were the limiting factor in the one I made. I read somewhere about someone using a "sprayer" to seed the VDG. This was a HV device that sprayed ions onto belt to be picked up at the top. Maybe then it doesn't classify as a VDG? Still neat though.
EDIT=> Another thought about a belt. See if you can get your local firestation to give you some old hose. There's a rubber liner inside that might work well, especially if you kept the canvas stuff on one side. Just a thought. We throw hose away all the time in the FD I am a part of. You can get it in many sizes too.
I can help you to solve some of the problems you will/might encounter if you like. I am "refurbishing" mine right now, but the basement is getting finished in a month or two so I can't get into any of my bigger projects at the moment.
For the belt, it will likely be easier if you make your own. There are two kinds of home-spliced (glued) belts that I am aware of that give excellent results. They both come from the same supplier, which is McMaster.com.
One of them is called "Vinyl-Laminated Nylon Fabric" (the thinnest), and the other is called "Coated Nylon Fabric" (also the thinnest). The nylon mesh backbone is very, very strong in both materials and will allow you to tighten your belt and crank up the speed (but not until it is ready!!!). The polymer coating is needed to keep the combs from neutralizing the charged roller, which is why your rollers cannot be the same material as the belt surface!
