  • Guests: 25
Shaun (34)
Spedy (30)
05/01 Shaun (34)
05/01 Spedy (30)
05/02 Adam Munich (30)
Replacing Single Capacitor with a MMC
Zorba
Mon Aug 06 2007, 08:10AM Print
Zorba Registered Member #169 Joined: Mon Feb 13 2006, 08:30PM
For my first tesla coil I'm working from designs from a book, however in the book they use a single capacitor and I was hoping to substitute it for a MMC. The book suggests using .005mfd/10KVAC capacitor so could I just get ten .15mfd/2KV capacitors and set those up in a capacitor bank and substitute that for the single cap?
If not how would I determine the quantity of capacitors that I need and also what would be the best ones to get? If it's important I'm using a 6.5KV/20ma transformer.
Mon Aug 06 2007, 08:53AM
You should use an mmc as it's reliable/proven/economical
For 6.5kV 20mA you'd be better using 10 to 15 nF (0.01 to 0.015 uF)
which is (10 to 15) x .15mF giving a nice safety margin for voltage ratings.
Zorba
Mon Aug 06 2007, 09:50PM
Thanks for your help
Just to double check so that I don't end up buying the wrong thing, would these work?
five of these:
or ten of these:
sparky
Fri Aug 10 2007, 04:29AM
I've always been one to push the 942 series of caps from CDE. They are very tolerant of overvolting and survive VERY VERY nicely on pulse discharge curcuits!
