  • Guests: 25
Adam Munich (30)
Alfredo Texacca (60)
05/02 Adam Munich (30)
05/02 Alfredo Texacca (60)
05/04 Matthew T. (35)
First Tesla Coil Problems
Tenicus
Thu Aug 02 2007, 01:31AM Print
Tenicus Registered Member #864 Joined: Tue Jun 26 2007, 07:26PM
Hi everyone
Im finishing up my first coil. Here are the specs:
NST- 10.5/30
MMC- 15 cornell dubilier 942s in series
secondary is 4.5 inch diameter, 20 inches tall
static spark gap
Problem is when I turn it all on the spark gap fires ONCE and then everything is silent. No noise, no sight, nothing.
The spark gap is 5 brass balls. If I wire it so that it is essentially a single static spark gap ( 2 brass balls) the spark gap will keep firing but I still get no sparks.
Any other arrangement (3 balls, 4 balls or all 5) and it fires once and everything stops. What could be the problem?
Hazmatt_(The Underdog)
Thu Aug 02 2007, 02:04AM
You're out of tune.
Lp Cp = Ls Cs. Do some rough calculations to find your ballpark primary inductance, then move your tap connection around to find the longest arc length at lower power levels, then increase the input power and you'll be in tune.
ArcLight
Thu Aug 02 2007, 03:56AM
ArcLight Registered Member #341 Joined: Thu Mar 23 2006, 07:41PM
Is there any chance that your NST has GFI protection?
Regards, ArcLight
Tenicus
Thu Aug 02 2007, 07:42PM
No I dont think so.
I messed around with the tuning and its working better now. Thanks guys.
