  • Guests: 25
Adam Munich (30)
Alfredo Texacca (60)
05/02 Adam Munich (30)
05/02 Alfredo Texacca (60)
05/04 Matthew T. (35)
help with DRSSTC
Danielle
Mon Jul 23 2007, 03:21AM Print
ok so I got my full bridge finished but when I connected it I tried the gates and with no power across the IGBTs the GDT buzz normally but when I connect up the power all gate activity stops like it is under extreme load. I dont understand why this would happen. any guesses I would love to get this up and running. when I lower the voltage across the IGBTs to zero the gate operates again. dont know if this will help but I found gate activity comes back at 1.5V and the AC voltage with a DMM is 1.5V but on a scope 30V. also when I dont have the primary connected I can bring the voltage up but it dosnt switch anything, but the gate is still active.
Thanks for the help,
Daniel.
edit
also I got the gate to be active but its quiet and loaded if I reverse the legs of the IGBTs gate, I can bring up the voltage but the middle of each half bridge is at 2V less than the supply voltage I don't think they should be doing anything. also the IGBTs are good as far as a diode test goes.
CT2
Mon Jul 23 2007, 05:16AM
CT2 Registered Member #180 Joined: Thu Feb 16 2006, 02:12AM
What circuit are you using? If it's steve wards and you dont have any tesla coil for it to get feedback from, then it might start switching at a lower frequency that you can hear as a buzz. I believe that's what happend to me, when I was testing one of my coils the same thing happend.
Danielle
Mon Jul 23 2007, 05:22AM
it is steve wards but I located the problem is in the new half bridge I built so its time to debug. I got it working just as well with the new capacitors though. I was using it with a coil, and I increased the primary tank capacitance but the coil is still pouting out the longest sparks at the same number of turns.
Danielle
Wed Jul 25 2007, 04:53PM
ok I am stumped it wont work anymore after I packedged it I caint figure out the problem I would really appreciate help.
edit
I really dont know what is going on but its working and its really nice. I am planning to take photos tonight. I dont want to finde the problem because im worried it wont work anymore.
