  • Guests: 25
Matthew T. (35)
Amrit Deshmukh (60)
05/05 Alexandre (32)
05/07 a.gutzeit (63)
05/08 wpk5008 (34)
What is the most powerful DVD laser
Danielle
Fri Jul 20 2007, 05:18PM Print
I was wondering for my knowledge and for others if people who have removed the DVD diode from a drive what model has the highest power output? I was also thinking of getting a light scribe drive as I think the laser burns the image onto the disc probably it has a very high power output.
Thanks for the help.
Madgyver
Fri Jul 20 2007, 06:08PM
I don't know if lightscribe drives are expecially strong or not, cause I never found such a device as junk, but I guess it wont make a big difference.
The image is not burnt into the disc, the disc has a special coating sensitive to the specific laser wavelength, making it change its color. Actualy just the same thing as used for the "data side" of the disc.
The key here is writing speed. The more speed the faster the DVD has to spin. If it spins very fast, the exposure time to the laserspot gets shorter, so the laser has to be stronger to make any effect.
Danielle
Fri Jul 20 2007, 06:23PM
thanks I was thinking of getting a 18X DVD and 8X DL speed samsung drive because the faster ones have the flat laser package not the can. I will be mounting it with a collimator lens. do you think it will be a powerful laser for burning/cutting/etching plastic?
Sat Jul 21 2007, 01:51AM
The power available from a dvd-r laser is directly proportional to the drive speed--so the faster the drive the better.
You aren't going to burn anything with a dvd-r laser, although when focused it is very possible to etch plastic. I have also heard of people using them to fuse finely ground plastic to make 2d/3d structures. If you want to be able to set things of fire your really want to have at least 10w of power available (CO2 laser would be ideal, although it is possible to get fiber coupled arrays of diodes for almost reasonable prices on ebay--just don't get the bare diode bars as they can't be focused worth a crap).
Danielle
Sat Jul 21 2007, 02:57AM
thanks I may work on a CO2 laser though the tube is verry expensive and would be very hard to make. I just ordered the drive and I did reaserch and It contains a 280mw red laser diode in the 9 or 5 mm package can.
c4r0
Sat Jul 21 2007, 09:26AM
c4r0 Registered Member #151 Joined: Sun Feb 12 2006, 02:53PM
I found this picture on other electronic forum:
1185010011 151 FT28705 56 1183184340
Sat Jul 21 2007, 02:01PM
GreySoul Registered Member #546 Joined: Fri Feb 23 2007, 11:43PM
I can make you a CO2 laser tube for very cheap - it's not as fancy as the $500 commercial tubes, but the last laser made with one is still welding titanium body jewelery 3 years later, so it must have worked. PM me if interested.
Madgyver
Sat Jul 21 2007, 04:01PM
Well I could tell you what to expect from a DVD laser diode, but wh don't you look for yourself:
These were made with diodes from 14x Drive If I recall correctly.
EEYORE
Sat Jul 21 2007, 04:57PM
Rocketry76 wrote ...
You can get brand new sealed 10watt c02 laser tubes on ebay for 199$. I dont think you will be making a successful c02 laser for cheaper than that. All you need is a HV power supply(your deffinately in the right place for that wink )
As to DVD lasers for burning, why on earth do you want a DVD laser?You can get a diode laser producing many times the power of these DVD lasers on ebay. Ive had 2 watt fiber coupled diode lasers(IR) than QUICKLY etch.
Matt
Madgyver
Sat Jul 21 2007, 05:39PM
Well I still guess these 2W diode lasers cost more then 2€ for a junk DVD-drive. That should explain why.
I got about 7 drives from a repair shop for 12€ total.
Cheap fun if you ask me.
