  • Guests: 24
Adam Munich (30)
Alfredo Texacca (60)
05/02 Adam Munich (30)
05/02 Alfredo Texacca (60)
05/04 Matthew T. (35)
Spark Gap noise supression
Thu Jul 19 2007, 10:06AM
Whatever material you use to sound-deaden your spark gap, please make sure it's fireproof! suprised You can combine blowers and soundproofing, by having the air flow through an acoustic silencer. The sound from a spark gap is mostly high frequencies, so it should be easy to deaden.
I'd also be interested to hear of your experiences in building simple HV supplies. I was wondering about the possibility of making a general-purpose regulated HVDC supply based around ignition coils driven in flyback mode by a TL494. They may not be as efficient as flybacks, and the lower frequency would make the output harder to smooth, but I think the toughness of oil-filled coils would make up for it. Plus I guess you can rectify it with a microwave oven diode, and easily change the polarity of the output by swivelling the diode through 180'. Just try that on a flyback with a built-in rectifier.
Thu Jul 19 2007, 11:04AM
I've found ignition coils to be pretty reliable
(but I'm biased, I used to design electronic ignition for Lucas in the 70's)
The main drawbacks are fairly high leakage inductance (about 10% for a typical 5mH coil)
and audio noise as they need to be switched in the 1 to 4 kHz range for max power throughput
(if a 12V battery/supply is used then the frequency needs to be in the 100's of Hz range)
That's ok for a 'noob' supply since it gives a simple indication of operation
and with a TC the noise is negligible.
For a general purpose hv supply it can get a bit annoying after a while though.
