  • Guests: 15
kg7bz (68)
steve516 (31)
05/17 Finn Hammer (72)
05/17 Blue Adept (43)
05/17 Nickel (68)
soldering gun
Omicron
Thu Mar 02 2006, 12:05AM Print
Omicron Registered Member #131 Joined: Fri Feb 10 2006, 09:25PM
ZD-99 SOLDER STATION
ZD Electronic Tools ZD-99
General purpose solder station for the hobbist. Adjustable from 5 to 50 Watt (800 deg. F max) heat output for reparing PC boards to soldering transformer terminals. Station provides on-off switch, knob to control wattage, built-in stand, tip cleaning sponge & 1/32" point tip. 115 VAC line.
Base L: 5-5/8” X W: 4-9/16” X T: 3-5/8” WT: 1.8
Data Sheet
http://www.mpja.com/directview.asp?product=15860+TL
Does this seem like a good purchase to you? Is the site reliable?
Tell me if the link is not working I’m new to this. All help will be apeciated!
[Edit: Repaired broken link]
Thu Mar 02 2006, 12:16AM
Its hard to say if this is a good purchase without knowing what your needs are and what you plan on soldering as well as what your budget is.
Omicron
Thu Mar 02 2006, 12:28AM
All its going to be used for is general soldering, and removing of components from old electronics, budget is $50. My old soldering gun just died, So I am looking for a new one that will last.
Bjørn
Thu Mar 02 2006, 12:52AM
At $15 I would not expect it to be good quality but at that price it would not matter. A brand name quality one would cost many times as much so you have little to lose if it turns out to need replacement in a year or so.
Omicron
Thu Mar 02 2006, 02:05AM
I have been browsing the site and it seems like an Electronics Goldmine. Does it seem reliable? Thanks for fixing the link. Any more options on the station?
Thu Mar 02 2006, 03:17AM
MPJA is a good site, I have ordered a lot of stuff from them smile
Fast shipping, uber easy to return stuff, good people.
Thu Mar 02 2006, 10:36AM
It looks like a temperature controlled iron, but it's not. It's just an ordinary soldering iron with a lamp dimmer type circuit bolted on. But for $15, I think that's pretty good.
As for the company, I always remember what my mom said: Never trust an electronics store that can't spell "Hobbyist" wink
joshua_
Thu Mar 02 2006, 10:48AM
joshua_ Registered Member #61 Joined: Thu Feb 09 2006, 05:50AM
If your budget is $50, then I totally recommend the Weller WLC100. Rock solid iron. Sort of like the one there, but made by a company that I've heard of and know to be good. I love mine.
Thu Mar 02 2006, 12:26PM
I agree. If you are planning on using it for additional electroncis projects, you might as well as spend the $50-100 and get a decent iron, otherwise this iron might last you a month or two, and then you'll be looking for a new one anyways.
Thu Mar 02 2006, 01:37PM
Arg, $100 is a lot of money for a soldering iron, but if you're going to do a lot of soldering, it could be worth it.
After breaking a bunch of those cheap yellow Antex irons, I bought the handle part from a Weller temperature controlled iron and built my own controller unit (based on a bunch of op-amps, some 74xx logic chips and a triac) to drive it. The handle alone was about $90 ten years ago, but it's worked fine ever since with only a couple of replacement tips. The tips last so much longer than on cheap irons, although I guess it helped that I made the controller turn down to 150'C if you leave it alone for 15 minutes.
The cool thing about a temperature controlled iron is that it adjusts its own power output to match what you're soldering.
At work we have a whole collection of temperature controlled solder stations from Xytronic and JBC. They all seem to work just fine, and the Xytronic ones are quite cheap. The JBC has a minuscule tip for surface mount work.
