  • Guests: 22
Adam Munich (30)
Alfredo Texacca (60)
05/02 Adam Munich (30)
05/02 Alfredo Texacca (60)
05/04 Matthew T. (35)
SSTC by rayer.ic.cz
dingo27
Wed Jul 11 2007, 12:33AM Print
dingo27 Registered Member #890 Joined: Tue Jul 10 2007, 10:06PM
Hi, I´m new to TC, but I want to ron one, so mine looks like this:
some photos
It is builded with BUY69A (SU 169 replacement), everything is as in
rayer´s page
but not working
It is consuming 2A, 10V (power source is 20V, but not ideal) and nothing happens, maybe it is little voltage...
I´m crazy with it, plz help... cry
should it help when I add voltage multiplier behind trafo 230/16V to got 30V ? I know, it must be exactly 30V(or less) but shoud it be stabilizated throug LM317 T to 30V ?????(I am getting of it 3A with perfect cooling, that 10V/2A is also based on that)
Wed Jul 11 2007, 10:19AM
I haven't tried this circuit,
but you could try reversing the connections to EITHER L1 OR L2
To check polarity of feedback for oscillation.
dingo27
Thu Jul 12 2007, 10:36PM
And if I want to make some sparks (but not with ignition coils), should I gave to TC about 650V DC ???
I know it should be AC, but can it vork with DC (from multiplier)?????... making some highvoltage caps, not too big TC, some primary and secondary, spark gap...
It is good idea or i shouldn´t do it because it will not work ???
Am I crazy or nobody wants reply to this ?
