  • Guests: 28
Adam Munich (30)
Alfredo Texacca (60)
05/02 Adam Munich (30)
05/02 Alfredo Texacca (60)
05/04 Matthew T. (35)
SSTC help
Munkey
Sun Jul 08 2007, 03:27PM Print
Munkey Registered Member #588 Joined: Sat Mar 17 2007, 11:06AM
Hi,
I am new to sstcs and high power electronics in general, however I have drawn up what I think is a halfbridge sstc schematic, I wanted to have some kind of feedback so I don't have to tune it but I have no idea how to do it. Anyway the schematic is here: Link2 Do you think it would work? The pic chip give an output like a flip-flop. The component values I have not given because I haven't calculated it yet.
Thanks,
Sun Jul 08 2007, 04:08PM
Here are some observations;
1)
The KBL04 bridge rectifier for 230Vac is too puny for my liking,
I'd use the highest current cheap bridge rectifier I could get
e.g. KBPC3504 400V 35A (GBP 1.60 from Maplin UK)
2)
I'd add a line filter (rfi) to the 230Vac input
3)
If the HVDC capacitor is large (>= 1000 uF) you will probably need a current inrush protection device
4)
There is no need for diodes across the two half-bridge capacitors
5)
I'd put FAST diodes across the half-bridge transistors
6)
Your entire gate-drive circuit is complex and wrong
Have a look how others do it.
7)
The 7812 regulator isn't required, it will probably cause more trouble than it's worth,
just use a suitable voltage transformer and capacitor.
It's VERY easy to blow up SSTC transistors, like you said, there's no feedback control of frequency.
I suggest you copy a simple/proven SSTC design before designing your own - saves sorrow and cash!
Sun Jul 08 2007, 04:17PM
why do you use such a complex gate driver one ucc3732 and one ucc37321 would be a lot simpler to use. I started with this sstc circuit Link2 it's really easy to understand and to buid.
Now it should work
Munkey
Sun Jul 08 2007, 04:24PM
Sulaiman, ill redesign my circuit then post it again.
Dalus, Your link doesn't work....
lardembargo
Mon Jul 09 2007, 12:08AM
lardembargo Registered Member #887 Joined: Sun Jul 08 2007, 10:24PM
Don't want to hijack the thread or anything but I was thinking of trying out the same miniSSTC you've provided a link to, so hopefully this is still ontopic. I'm new to sstc stuff too, have only built a DC coil based on a MOT before.
Anyway, looks like the SSTC5 schematic shows some capacitors placed between chip +ve power rail and the common -ve rail, which I think are decoupling capacitors? The 0.1uF ones like C2 and C14. What kind of capacitors are good for decoupling - they're not polarised in the schematic so I was guessing polyester MKT ones or maybe ceramics?
Any assistance appreciated, I tried searching for decoupling and came up with lots of hits but not really any guidance for what to use. Cheers anyway.
Tom540
Mon Jul 09 2007, 01:59AM
Tom540 Banned on 3/17/2009.
Heres the circuit i always use
]1183946250_487_FT28058_sstc_logic.pdf[/file]
Decoupling caps are either poly or Tantalum 35v or 50v.
Munkey
Mon Jul 09 2007, 06:40AM
I guess I was trying to run before I can walk... again...
Tom540, your schematic is a little confusing as there are several 555 timers up top with only the power connected...
I think I will go with steve's minitesla circuit.
Next time I will try to design my own again! and fail!
Tom540
Mon Jul 09 2007, 07:05AM
Yeah those are just to show the power connections for the digital parts without having them near the actual part.
Munkey
Mon Jul 09 2007, 03:30PM
Ah right, ok.
I have a question about GDTs now, I have seen some designs where one of the secondarys is crossed over, I am guessing this is to invert it, but what about the ones that don't?
Is the aim to push and pull current in ither direction of the GDT pimary to power each FET, right?
Mon Jul 09 2007, 04:48PM
Can you give me a design where the secondary isn't crossed over, I can't remeber any of those designs.
