  • Guests: 34
Matthew T. (35)
Amrit Deshmukh (60)
05/05 Alexandre (32)
05/07 a.gutzeit (63)
05/08 wpk5008 (34)
Laser Pen that writes into plastic! [video]
Madgyver
Fri Jun 15 2007, 10:26AM Print
Hi
I just finished my very crude work on a "laser pen" (its not actually meant for use as a laser pointer) made from a DVD laser diode. The laser is strong enough to be used to engrave/write into black plastic.
Look for yourself:
Ever seen a laser pen that could literaly write? With the LASER cheesey
some pics of the contraption after some posts.
Sun Jun 17 2007, 12:53PM
Nice. What is the output power? Did you collimate the beam, and if so how did you do it? I have a junked CD-RW burner which should contain an IR laser diode, not as much power as a DVD laser but still enough to be fun. I think I might try using the lens form a standard laser pen for collimating.
Madgyver
Sun Jun 17 2007, 08:51PM
Output Power schould be around 100-120mW. The Beam is only crudely collimate with the focus lens of that unit. (The Lens which sits on voice coils)
The laser diode is mounted into a metal tube and the lens can be adjusted by turning a screw.
70b18c317a56725cae9d573b2c80b446
6cc38e91347ae4464deee253da8e3462
This is the lens.
Bbb5033bfef49adb33a28a658a3dbfb0
j.azz
Tue Jul 17 2007, 07:54PM
j.azz Registered Member #888 Joined: Tue Jul 10 2007, 06:52PM
That's nice.
I just bought a new DVD burner to have a reason to disassemble the old one ;)
What do you use as power supply? Currently I'm using a 3,7V mobile phone accu with a 8,3 ohm resistor, giving about 400mA.
To Uzzors:
The infrared lasers are also fun. If well collimated they can burn black plastic too.
c4r0
Fri Jul 20 2007, 11:37AM
c4r0 Registered Member #151 Joined: Sun Feb 12 2006, 02:53PM
j.azz wrote ...
I've built a simple regulated current source for my DVD-RW laser diode. Its very useful :)
1184931228 151 FT26961 Ld Zrodlo
BTW check out my DVD laser ploter : Link2 :)
Fri Jul 20 2007, 02:01PM
Nicely done, looks quite overpowered, do you have a way to measure the optical power?
c4r0
Sat Jul 21 2007, 09:23AM
Dalus wrote ...
Actually no. But I can measure a characteristic of the laser diode using a photodiode. It gives me a shape of characteristic without scale on the optical power axis (or with photodiode current on this axis):
1185009384 151 FT26961 Dvd Chart
j.azz
Sun Jul 22 2007, 08:33PM
hmm, I don't know what I did wrong but I just killed two of my IR-LDs with measured 10mA... Aren't 12V bad for these LDs?! Or have I a momentarily lack of intelligence at the moment... confused:(
Madgyver
Sun Jul 22 2007, 08:58PM
Killing the diode with 10mA sounds odd. The 12V from the schematic, are not directly connected to the diode of course. The circuit automaticly regulates it, to achieve constant current.
Maybe you reversely connected the diode?
j.azz
Mon Jul 23 2007, 04:53PM
arggg.... after several testings with normal LEDs, which where successfull, I finally killed my 650nm LD... cry mad I really don't know haow it happened, not connected in reverse, measured current below 30mA, just turned into a useless and poor red LED!
