  • Guests: 38
05/04 Matthew T. (35)
05/04 Amrit Deshmukh (60)
05/05 Alexandre (32)
Scope measurements on an SSTC
Josh Johnson
Thu Jun 14 2007, 02:00AM Print
Josh Johnson Registered Member #793 Joined: Sun May 20 2007, 06:50PM
How do you all make measurements on the gate-source of MOSFETS/IGBTS in the lower section of the bridge to look at the gate signal? (I know , I don't want to ground the high-side) My 'lab' is the garage and is full of GFI outlets. Over course anytime I connect the ground of the single ended probe to the bottom of the H-bridge the GFI trips because I am providing a path to ground for the neutral. The supply to the bridge is a variac to a full-wave rectifier/cap. I don't have a differnetial probe and tried the two probe A minus B deal but didn't have very good results. No battery powered scope for me to use either.
Use a battery for the supply to the H-bridge?
Some other clever isolation scheme?
Maybe there is something obvious I am missing.
Thanks.
Thu Jun 14 2007, 03:24AM
You arent simply grounding neutral if you are probing *after* the bridge rectifier. You are literally shorting out half cycle DC.
Anyway, what you need is an isolation transformer. I happened to find a nice 120V to 240v/480v 500va transformer that has been plenty for all of my work (it can go to 1kW++ for short periods of time). Of course, for low power testing a smaller transformer at a lower voltage would work. Id suggest perhaps winding your own transformer on an old MOT, since they are easily found and relatively easy to take apart (just cut off 2 welds along the laminations). You typically dont want to run full voltage while probing on a nice scope anyway, so even if you only get 60VAC that should be enough for most cases.
Josh Johnson
Thu Jun 14 2007, 04:08AM
Duh. Should have thought that one through a bit more. The bottom of the H-bridge just looks so ground friendly sitting at the bottom of the schematic and so far away from the rectifier (at least the way I was drawing it). smile
I thought about a transformer for isolation but thought the transformer impeadances would screw with the signal especially at the gate. Are the losses so small at higher frequencies they just don't have a big effect on the signal?
Do you put any load on the scope side of the isolation transformer or just run it open with the probe connected?
That sounds like a great solution though; I should be able to dig up a decent transformer somewhere.
Thanks for the help Steve.
Thu Jun 14 2007, 04:51AM
I think you are a little unclear about what we are doing. You clamp you scope directly onto across the gate/source, but you float the whole coil on an isolation transformer.
Josh Johnson
Thu Jun 14 2007, 05:18AM
By 'float the whole coil' you mean placing the isolation transformer anywhere in the input 60Hz AC before the rectifier? This makes sense.
Wolfram
Thu Jun 14 2007, 06:16AM
Yes, that's exactly what you need to do.
A very simple way to make a relatively powerful isolation transformer is to connect the high voltage output of one MOT to the high voltage output of a second MOT, and then take the voltage out at the primary of the second MOT.
Thu Jun 14 2007, 05:04PM
Yes, i should have been more explicit. The isolation transformer is for supplying raw AC to the power input of the power electronics. Still, be respectful of the voltage present!
