  • Guests: 24
Linas (34)
Toasty (29)
05/15 Linas (34)
05/15 Toasty (29)
05/16 kg7bz (68)
Aluminum & mercury
Jim
Tue Feb 28 2006, 08:48PM Print
Jim Dunce.
Registered Member #28 Joined: Fri Feb 03 2006, 03:29AM
I attempted the mewrcury and aluminum amalgam with a soda can and some mercury from a thermometer, however, it did absolutely nothing.
craigsarea
Tue Feb 28 2006, 10:17PM
craigsarea Registered Member #130 Joined: Fri Feb 10 2006, 08:12PM
Yeah I've tried it before and it's quite hard to get started:
I think the aluminium oxide layer gets in the way. In the end I used gallium to break it down. You could probably use HCl instead, which is something I've been meaning to try for a while now.
LowCurrentHV
Wed Mar 01 2006, 01:53AM
LowCurrentHV Registered Member #272 Joined: Tue Feb 28 2006, 11:07PM
Also try using a better source for the aluminum, a lot of cans are alloys and have layers of anodizing and plastics covering the actual aluminum. A good bet would be to use an aluminum bar from Home Depot, it's like $3.
Thu Mar 02 2006, 01:26AM
what reaction are you all talking about? What is it suppose to do?
Omicron
Thu Mar 02 2006, 02:13AM
Omicron Registered Member #131 Joined: Fri Feb 10 2006, 09:25PM
You have to use mercuric chloride, not metal the mercuric chloride is the activator and the reactivity of Al does the rest.
ragnar
Thu Mar 02 2006, 05:41AM
Omicron, mercuric chloride is not to be toyed with.
I would think Jim is talking about the mercury + aluminium and amalgamation.
Omicron
Thu Mar 02 2006, 09:37PM
Okay I thought he was talking about the rapid oxidation of Al not alnagamation for that try silver it’s a lot easier.
Jim
Mon Mar 06 2006, 12:17AM
Jim Dunce.
I scraped the oxide layer off the Al and then applied to the liquid Hg and it still did nothing, even after sitting for a week.
Dr. Shark
Mon Mar 06 2006, 10:01AM
I really think your best bet is to use Gallium. If you try to scratch the oxide layer is will reform faster than you can scratch.
govtcontact
Fri Mar 24 2006, 02:51PM
govtcontact Registered Member #343 Joined: Fri Mar 24 2006, 02:45PM
A simple source for Al is Al foil. Cut or tare into pices ~ .5 inch X .5 inch. Place into a container and add a solution of NaOH (20% NaOH solution). Allow the sollution to remove the oxide for about a minute or so. Drain the solution and rinse several times with fresh DISTILLED h2o.
Next, carry on with the rest of the procedure.
